Please change my forum name to GTRWGN. I've been away from this site for some time. I think I tried to make a new account a few years back under the guise GTRWGN but alas, I can not remember my password for that account.
Thanks in advance!
Thanks in advance!
Also. How can I change my email address? Seems SAU still has me as using a Hotmail account!
There is an account with GTRWGN as a logon name so I can't change your name to match it unfortunately. If that is your old account, and you still have access to the email account it is tied to, you can reset the password - the email address in that account goes to an import business, if that helps you.
To change your email address -
1. Click your name in the top-right corner, choose "My Settings" from the list
2. Email & Password tab on the left
Follow the instructions in there.
Hi can I please change my username to GroceryZilla of it's not taken/an issue.
Also looking to change my password, had to do a reset and now have no idea how to write in a regular password. Does this app have that option?
  • 4 weeks later...
Both done.
Matt - yes you can reset your password :-
  • Click the arrow next to your username in the top right
  • Choose "My Settings"
  • Click "Email & Settings" on the left
  • The setting should be in there, I actually can't confirm as the system forces admins to use the admin control panel to manage our own accounts.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
