  • 10 months later...
It doesnt matter. Its just flowing through it.
Id probly put it in at the top, being pedantic and thinking that it might be easier on the oil pump lol. But either way, it will be at XPsi once its built pressure, so if its already running dont worry about it.
  • 3 months later...
Just abit confused on something.
Sorry i'm new to this oil cooler stuff.
Im going to get a DEFI DIN gauge peice and also looking at getting a Greddy Oil Cooler. Something like this for my R32 gtr. http://www.ebay.com.au/itm/Greddy-Trust-Oil-Cooler-Kit-Nissan-Skyline-GT-R-R32-/170813641917?pt=AU_Car_Parts_Accessories&hash=item27c54954bd
Can someone please explain how id run it ? What hose goes to what and what adapter goes to what... This link has some difference peices that are confusing me to the pictures posted on page 1..
Sorry about the anoying question but id really appreciate it if someone can help me out .
Damn the RB26 and the lack of space.
Anybody uses a simple sandwich plate without the relocation kit on the RB26 - would love to see your installation pics.
Got a 10-row cooler and this adapter - hoses and connectors will be purchased later on, when I figure out where to mount the core - there just is stuff all room - even a drivers guard is full of hoses and bov's(I think) - passenger side guard seems so far away.
Would appreciate R33 GT-R installation pics.
  • 1 year later...
  • 8 months later...
It is a good idea to disconnect the ignitor or coil packs and crank the engine a bit to get oil through it. Remember not to continuously crank it for too long or you will fry the starter. 20 seconds on and 20 seconds off is fairly safe
My cooler is setup nearly exactly the same as John's. I havent seen that bracket on many 33's. I had to drill a hole in my carbon cooling panel for the top stud/nut so not really sure if this is standard or what
^ Thanks for that.
I mounted my oil cooler on the weekend. Will just need to find time to connect up all the lines and finish it off.
  • 4 weeks later...
Bit of a noob question here. So in the photo of the kit there are three hoses.
My understanding is that one hose connects the adaptor to the remote filter (So oil out of the block to the filter)
Then one hose goes from the filter to the cooler
Then one hose goes from the cooler back to the block
Is my understanding correct?
Cheers for the write up
My understanding is that one hose connects the BLOCK adaptor to the remote filter (So oil out of the block to the filter) - YES
Then one hose goes from the filter to the cooler - YES
Then one hose goes from the cooler back to the block ADAPTER - YES
Your understanding is correct!
Just ensure you get the correct hose orientation on the block adapter and the remote filter adapter.
I can't remember the orientation, but see the diagrams on page 1. I got them wrong first time around.
Cheers
Cheers
Thanks mate, So you mean ensure that the IN and OUT fittings on the adaptor match the same on the filter yeah?
Cheers again
Use bulkhead fittings to go from engine bay to outside, means you have to buy some extra ends for the braided line, but prevents rubbing and having to cut holes (or run the lines further to existing openings)
Mine are run with short braid from the oil cooler sandwich plate, to hardlines that go along the chassis rail to bulkhead fittings at the front to 2 more small braided lines to the cooler itself. The hardlines were free, and not completely necessary, but they just prevent things rubbing and look pretty neat
Bulkhead Fittings : Mine are ones for hydraulic hoses so are steel instead of aluminium. Might be cheaper for steel ones. Pirtek or any hydraulic hose shop should have them
Edited by 89CAL
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
