Do the brake swap it takes so much hassle out of having to replace brake parts. R33 GTST Calipers all around and rotors, from what I here there is bugger all difference in going to Brembos in terms of braking performance as they are still only 4 pot and 2 pot and the piston sizes are almost equivalent to the sumitumo calipers. The major difference with Brembos is you can fit a larger disk on the fronts but if this is really an issue for you then Unique Auto Sports offer a large front disk conversioon kit for R33 GTST calipers which allows you to run a 350mm disk which is bigger than GTR brembos can run anyways. I think you can get this kit for around $700 which includes caliper brackets and new DBA rotors plus the price of calipers maybe a couple of hundred bucks from a wrecker. Anyways on a final note I have a full set of S2 Stagea Disks / calipers and pads sitting in my garage from my conversion they are still almost mint so if anyones interested then pm me.
So, ryan1600 would i be right in saying that 33 gtr and gtst calipers are the same? and if i were to buy the calipers and get some slotted rotors to suit, would they just be as easy as taking off my old rotors and calipers, then putting on new said calipers and rotors?
... i heard dba make gold slotted and dimpled rotors for 33's.... would look pretty sweet on my car :P (not to mention the braking upgrade)
i dont know...
s14, z32, R32 GTR and R33 GTST calipers are the same
R33 GTR calipers are Brembos
R34GTR are also Brembos
nah, Z32 front calipers are the same as R32 GTST. unsure of Z32 rears.
R32 GTR (non v-spec i believe) and R33 GTST are the same front. sumitumo calipers
R32 GTST, R32 GTR (non v-spec) and R33 GTST rears are the same.
R32 GTR V-specs are the Brembos, larger rotors.
all four spots fronts and 2 spot rears.
BKC34 have a read back a few pages. there is a few things mentioned that you need to alter to fit R33 calipers on.
Edited by QWK32
the best thing about the 32 gtr / 33 gtst brake setups are they
bolt straight on
much bigger than stock
cheap pads and plenty of choices
cheap discs dba/rda etc
setup around 500 to buy
It might cost more compared to a single replacement of pads and rotors for the standard stagea brakes, but by the time you get to the 2nd or 3rd change it will be much cheaper. and your car will stop much better in the meantime
bolt straight on
standard booster/master/lines okay?
yeah i used standard master, the 4 pistons are each much smaller than the 1 large standard one, I am not sure of the exact difference but I don't have a front/rear bias issues.
I re-used the front lines with the fitting inside the caliper removed - darrin covered this above. I also used the M12 bolts from 32 gtr with a small sleeve to match the 14mm diameter of the stagea hub. but that was it.
Don't you mean '2' standard ones? The fronts are twin-sliding aren't they?
(It's late & I can't remember...)
Hmm wonder if R34GTS-T rotors have the right offset and could be machined down? Would be a bit of a waste of diameter... but they are now available in the RDA group buy :happy:
you could get a fair idea by pulling off one of your rotors and sizing it up. then go on the DBA website and start checking the sizing of the stagea rotor to some of the other nissan rotors, maybe even toyota or ford, some of them run the same PCD as nissan.
yep, fronts are twin, rear is single.
So if this is true, then wouldnt an upgrade of 33gtst/gtr calipers and slotted rotors on the front, and swapping your standard 2 pot front calipers onto the back with some slotted rotors, be a really good braking system upgrade, but for not a hell of a lot of money?
i wouldn't bother, just looking at the size of the front calipers (slightly bigger then the front R33 ones) you'd probably run into a fitment issue trying to put them on the rear, with bolt hole centers, rotor offest may be off even if you put the front rotor on the rear. also, and i'm not sure about this, but it may cause issues with brake bias.
a couple of R33/R32 rear calipers aren't to expensive, and at least you know they are designed to be a rear caliper.
Edited by QWK32
yeh thats fair enough, i wasn't aware there was bias' with the front and rear calipers, but yeh that does make sense tho :)
so probably a full set of 33 calipers and some nice slotted rotors to suit i think would be a decent braking upgrade, and some good pads too of course :(
so will the r32/33 four spots fit m35 ??? :)
i'm sure you could get them to fit, just how much work would be involved is another thing. what do the M35's have standard?
do you think there might be a better match/upgrade with something off the V series skylines?
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
