Dixcel have direct replacement rotors for our cars (either standard or slotted)...but there are no distributors in Australia. This is according to Dixcel in Japan when I emailed them and ask about who is the distributor in Australia
As previously mentioned in here that you can get DBA rotors and machine the OD to match and fit the standard rotors (unless you've upgraded to R33/R34 rotors and callipers or you own a M35)
I'm looking for a set of Dixcel's locally but it's hard to find them and importing them in is expensive (due to the weight for shipping).
Whilst people in the know have ensured me that machining the OD of the disc is perfectly safe...IMO I don't want to chance it
Yeah I don't want to risk that either. Unless DBA or RBA have rotors that marry up to the C34 dimensions.
Japanese Import Spares in SA stock Dixcel rotors for Stageas, give them a call on 08 82660212 to see if in stock.
I called them today. Just the standard PD rotors, no slotted rotors unfortunately.
Well at least its a start on where you can get direct replacement brake discs...even if they are just the PD rotors. Did you ask them if they can get the SD rotors in?
If anyone's after rotors, GSL are having a sale: http://www.skylinesaustralia.com/forums/topic/378654-dba-stagea-and-gtr-rotors-on-special/page__pid__6037978#entry6037978
Some cheap DBA 4000 slotteds for M35s, not sure about C34s?
You should be able to get a set of plain rotors slotted for around $60ish; I'm pretty sure that's what I was quoted a while ago.
This is likely to be a dumb question, but would the standard M35 front caliper fit on the rear (with the correct size rotors)? It occurred to me that the fronts would be a decent upgrade for the rears, if they fit.
Because of the piston volume; I'd be willing to bet the brake bias will be a disaster, and you'd basically have no rear brakes.:ph34r:
Also the front rotor is basically the same diameter as the rear, just a little thicker, so you're not really gaining any mechanical advantage.
Edited by Daleo
OK, so would it be reasonable to leave the rears stock & put a big set on the front or would there be a bias issue with that setup as well?
I have upgraded the fronts to R32 GTR calipers with no downside to the overall braking performance.
I think most people have upgraded the front without touching the rear.
Cheers
Andy
I run R33 GTR with stock M35 rears.......no problems with the setup at all....I found it quite balanced........but I do run good pad's front and back though.
these would be a straight bolt on with the purchase of rotors.
http://www.importmonster.com.au/view?url=http://page.auctions.yahoo.co.jp/jp/auction/152870321&thumb=http://f4.auctions.c.yimg.jp/img301.auctions.yahoo.co.jp/users/7/1/7/8/ekemh777-thumb-1316858296286717.jpg&title=Z33%20Z%20BNR34
Edited by Jetwreck
Upgrading can be a PITA.
To fit 33gtst fronts to my S1 we had to sleeve the carriers from 14mm to 12mm.
To fit the 2pot RS4 fronts to the 25G, which are singles, we have to drill out the carriers from 12mm to 14mm. And HF Batman the carriers are so hard it is impossible to drill on the vehicle. To get the axle of you need a MF big rattler. then take to a machine shop to be drilled out.
What started out as a simple job is now over the single Grand mark. But both cars will have much better stopping power.
God bless Nissans. LOL :worship:
Edited by 66yostagea
Thanks Andy & Craig
When the time comes I will follow the same path & leave the rears alone, focussing on something nice for the front. Cheers for the clarification.
Now that the wheels are on, I shouldn't be having any trouble to fit brakes to my m35. I did the r33 gtst brakes on my c34 Stagea - already have the sleeves for the bolts, just can't remember what is involved with the brake lines? Is it the same for the m35?
Edited by jasevr4
I just used the standard brake lines on the M35.....just remember there is a restrictor in those callipers that you will have to remove........or cut down the bango bolt!
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
