Dixcel have direct replacement rotors for our cars (either standard or slotted)...but there are no distributors in Australia. This is according to Dixcel in Japan when I emailed them and ask about who is the distributor in Australia
As previously mentioned in here that you can get DBA rotors and machine the OD to match and fit the standard rotors (unless you've upgraded to R33/R34 rotors and callipers or you own a M35)
I'm looking for a set of Dixcel's locally but it's hard to find them and importing them in is expensive (due to the weight for shipping).
Whilst people in the know have ensured me that machining the OD of the disc is perfectly safe...IMO I don't want to chance it
Yeah I don't want to risk that either. Unless DBA or RBA have rotors that marry up to the C34 dimensions.
Japanese Import Spares in SA stock Dixcel rotors for Stageas, give them a call on 08 82660212 to see if in stock.
I called them today. Just the standard PD rotors, no slotted rotors unfortunately.
Well at least its a start on where you can get direct replacement brake discs...even if they are just the PD rotors. Did you ask them if they can get the SD rotors in?
If anyone's after rotors, GSL are having a sale: http://www.skylinesaustralia.com/forums/topic/378654-dba-stagea-and-gtr-rotors-on-special/page__pid__6037978#entry6037978
Some cheap DBA 4000 slotteds for M35s, not sure about C34s?
You should be able to get a set of plain rotors slotted for around $60ish; I'm pretty sure that's what I was quoted a while ago.
This is likely to be a dumb question, but would the standard M35 front caliper fit on the rear (with the correct size rotors)? It occurred to me that the fronts would be a decent upgrade for the rears, if they fit.
Because of the piston volume; I'd be willing to bet the brake bias will be a disaster, and you'd basically have no rear brakes.:ph34r:
Also the front rotor is basically the same diameter as the rear, just a little thicker, so you're not really gaining any mechanical advantage.
Edited by Daleo
OK, so would it be reasonable to leave the rears stock & put a big set on the front or would there be a bias issue with that setup as well?
I have upgraded the fronts to R32 GTR calipers with no downside to the overall braking performance.
I think most people have upgraded the front without touching the rear.
Cheers
Andy
I run R33 GTR with stock M35 rears.......no problems with the setup at all....I found it quite balanced........but I do run good pad's front and back though.
these would be a straight bolt on with the purchase of rotors.
http://www.importmonster.com.au/view?url=http://page.auctions.yahoo.co.jp/jp/auction/152870321&thumb=http://f4.auctions.c.yimg.jp/img301.auctions.yahoo.co.jp/users/7/1/7/8/ekemh777-thumb-1316858296286717.jpg&title=Z33%20Z%20BNR34
Edited by Jetwreck
Upgrading can be a PITA.
To fit 33gtst fronts to my S1 we had to sleeve the carriers from 14mm to 12mm.
To fit the 2pot RS4 fronts to the 25G, which are singles, we have to drill out the carriers from 12mm to 14mm. And HF Batman the carriers are so hard it is impossible to drill on the vehicle. To get the axle of you need a MF big rattler. then take to a machine shop to be drilled out.
What started out as a simple job is now over the single Grand mark. But both cars will have much better stopping power.
God bless Nissans. LOL :worship:
Edited by 66yostagea
Thanks Andy & Craig
When the time comes I will follow the same path & leave the rears alone, focussing on something nice for the front. Cheers for the clarification.
Now that the wheels are on, I shouldn't be having any trouble to fit brakes to my m35. I did the r33 gtst brakes on my c34 Stagea - already have the sleeves for the bolts, just can't remember what is involved with the brake lines? Is it the same for the m35?
Edited by jasevr4
I just used the standard brake lines on the M35.....just remember there is a restrictor in those callipers that you will have to remove........or cut down the bango bolt!
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
