Ditto. The 25G, S1 RS4 and 33GTST pads are all different. I have some of the shims but not all. Let me know how you get on trawling the wreckers and if you are going ebay.
Would 300ZX fit R33GTST 4 pots? And I guess i will need a set for the RS4 stock 2 pots.
Any pad that fits a Sumitomo 4 pot caliper will be suitable; that also includes 200SX, Subaru, etc.
Thanks heaps for that^
Its the search criteria that was getting me, I was trying things like "squeal+plate" etc with no result.
"Brake shim kit" wins.
I have not a single item installed in that picture.
Never mind.
If my wrecker trawl fails I will just get a set in from the US like shown.
Thanks again.
No drama; it might even be worth pricing them through Nissan in Australia, you never know what the prices are like.
I've seen wreckers try to charge through the roof for those parts; and I'm sure they remove them just so they can take two bites.:spank:
Regarding the R34 4 piston caliper squeal plates/pad shims.
I found a part number through searching a bit further (silvia.com i think had a thread) and rang Nissan Rockingham.
So the part number I got was 41080 - 21U25.
The price was something like $180, to be honest I tuned out once the kid said one hund....
The guy on the phone couldn't explain adequately what the kit contained so I may have been getting more than i asked.
Dont know if it would be worth trying other nissan dealers.
Anyone have any confirmation on the part number above and whether the price is legit?
Also this was found in the thread..
Frontbrakes.pdf
Edited by shane344
That pic is the goods. The set is listed as 41080K, GC Nissan quoted $169 ex Japan
Import Monster may be better if we can order a few sets.
Edited by 66yostagea
This set off Ebay is starting to look pretty good now huh?
http://www.ebay.com.au/itm/300ZX-Z32-FRONT-BRAKE-HARDWARE-SHIM-KIT-OEM-NEW-/330670362953?pt=Motors_Car_Truck_Parts_Accessories&hash=item4cfd7d5149#ht_594wt_1037
Maybe get a few people together to save on postage.
Edited by Daleo
cheers for the link mate
TBH I think they are a good buy at the price they are. Going to (eventually) buy a set for my Stags front R32 sumitomos
Well I am going to get some. If any one wants a set about $60 will cover purchase and post. Let me know ASAP.
The link that I posted will get them in your hand for $49.38 rolleyes.gif And that's without combining postage for multiple purchases.
Just sayin'
i used standard R34 GTT lines all round. but better to get braided front. rears are fine to bolt up. as for BMC its the Same as the R33/R34 cusco do one for the Stagea. there is a picture in the mod thread on here.
Hey guys.
Seriously long thread you got here. was skimming trough the pages and what i could see, The FRONT pads for a S1 is the same as for an Maxima -2000 right?
this is what i found at ebay:
Stagea s1 pads: greenstuff pads
Oem pads
Maxima qx a33 v6 24v -2000:
Oem nissan pads
brembo pads
they seem to be the same?
note: i didnt find the maxima brakes at first, but then i realised i was on the au ebay, not the uk one. maybe the pads are different on european models?
Edit: if you scroll down on the brembo ones it looks like they match the oem pads, measures are the same.
have anyone got the measurements for the stagea brakes? havent take mine off yet but will do this weekend.
/cheers from Sweden
Edited by potkin
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
