cheers lads! went with the 34 setup ($250 for callipers and pads), just need some rotors now.. i am rather lazy right at this point in time do i need to mess around with lines?? ;)
No, I have r34 front and back using the standard stag lines, the rears needed some different clips to attach but not sure exactly as it was done for me.
Go the 34 brakes on a s2 if you can
Someone asked about gtr rears, should be fine but you'll probably need tin snips to trim the backing plate/dust shield
thanks for that, anyone have any insight into upgrading the master cylinder going from stock s1 brakes, to 33 brembos?
I haven't tried that exact swap, but would not expect you need to change cylinders
I've run 33 gtr and g4 8 spots on my gtr without any bias issues. I've run 32 gtr and g4 8 spots on my stagea without any bias issues.
In the end, it is the total piston area that matters, the 32 and 33 gtr have about the same size pistons, the 8 spots have 8 very small pistons, and the stagea has 1 very large piston. you could always calculate the areas but I think you won't have an issue.
awesome, thanks heaps mate.
I changed my S1 brakes to GTT brakes with no issues. Later I put R32GTR brakes on the rear (essentially the same as GTT) and 330mm D2s on the front. I then put a BM57 master cylinder on which just means that with a larger area there is less pedal travel but more effort required. It would probably have been fine without the change.
sweet, if i have any issues with it, ill swap it out, but i figured it would be fine, just wanted to check with knowledgeable people.
Correct me if i'm wrong, but from what i have read online, 34 and 33 brembos are the same, and therefore gtr34 brembos should bolt up to my s1 all the same?
Edit: will a 324mm rear rotor and caliper off the later model gtr34's bolt up the same? or will i need dogbones to suit the bigger rotor?
Edited by HousewifE
trying to be a tightass and avoid spending 450 on dixcel rotors i spent 600 instead! :wacko:
250 - r34 gtt front callipers
80 - rotors and machining
130 - shim kit from nissan
140 - hpx pads and 1L brake fluid
Sorry to be a pain guys, I've read through countless pages of what Rotors will suit the S2 C34. From what I've gathered, the 34 GTT rotors are a direct fit, but I'm looking at going for some slotted rotors. I've read that shaving down the OD of DBA brakes for the 32GTR and 33GTST will work, but that information was posted a few years ago. Does anyone know of any direct replacement slotted disks for the S2?
Again sorry to be a pain, I need to get them replaced ASAP.
Thanks
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List:
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
