  • 3 months later...
and yes 32 gtr and 33 gtst calipers and rotors are interchangeable (they are 2mm different width from factory). 34 gtst calipers and rotors must be used together, they are different from all other brake sizes
12mm bolts with the sleeves works fine - I've just had mine done in the past month (beginning of November) and had no issues so far. Went from standard s1 C34 brakes to R32 GT-R.
I got the sleeves from Daleo (thanks again, mate!), and all is well - no movement, no clunking noises, etc.
Ok so my 2nd hand R34 GTT front brake callipers bolt on to the new RDA 310mm Rotors purchased for the NM35 but I now require new custom brake lines to allow them to work.
Certainly Didn't give a thought to that happening
But I have never carried out a changeover quite like it...
Thats modifying tho...
So what I found was $40 a side for rubber or $90 ADR approved braided
That didn't require a second thought...
Thanks Kurt from power brakes in Adelaide extremely handy guy see you tomorrow.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
