Hi all,
Putting the finishing touches on an order for new rims. The supplier has recommended the following.
18x8.5 +32 and 18x9.5 +38
Cars an R33 GTST S1
Can anyone confirm if there will be any issues with this?
Hi all,
Cars an R33 GTST S1
they will be fine
Hey All,
Here is my new set up on my new car.
Skyline model = A31 Cefiro
Wheel diameter = 18" Do-Luck Double Six rims :down:
Wheel width = 9.5"
Wheel offset = +15
Tyre size = Front 225/40/18 Rear 235/40/18
Modifications to fit = Flared/lipped guards approx. 20mm front and rear with 3.5 degree's front camber and 3 degree's rear.
Cheers
Phill
Edited by phillb
Skyline model = r32 4 door
Wheel diameter = 17 x 9
Offset = +25
Tyre size = Front 215/45/17 Rear 235/45/17
Modifications to fit = lipped rear, wider front guards... :D
Thinkin bout putting 20mm spacers on the front...could work, might be a little close to guards though?
Tried 25mm ones and are way too close to front bar and guard, looks cool but scared to crack more fibreglass!
will try 20mm ones soon...
Anyone run r33 gtr rims on a 32 with spacers? if so what size spacers on front and rear? Rear would be minimal size im guessing...
Cheers
Joey.
Skyline model = 1993 R32 GTR
Wheel diameter = 18" (Work XD9 Rims)
Wheel width = 4 x 10"
Wheel offset = +18
Tyre size = 4 x 275/35/ZR18 Semi Slicks (Not fitted in pics yet)
Modifications to fit = Just One, I lipped the rear arches. Also you need to make sure you buy the work hub rings overwise the wheels will be supported by the studs (not good) instead of the hub (good). My car is lowered so for the first few weeks it slightly rubbed against the front plastic wheel arch guide. No rubbing now.
Skyline model = 1996 R33 gtst
Wheel width = 2 x 9" and 2 x 10"
Wheel offset = +30 and +38 by recommendation, should have got a better offset
Tyre size = 2 x 235/40/18 and 2 x 225/40/18
Modifications to fit = currently fitted with no modifications at all.
Getting 20mm front and rear spacers and guards rolled tomorrow
Edited by blags
Skyline model = R32 gtst
Wheel diameter = 17" Buddyclub P1's
Wheel width = 9"
Wheel offset = +17
Tyre size = 215/45/17 front and 235/45/17 rear
Modifications to fit = 2.5 deg camber front 3 deg camber rear (too much havent got rear camber arms yet)
tucked in front lip a little will have to roll rear guards once take camber out but not by much
surprised the fit so well, though they would stick out way further
Skyline Model = 2000 R34 GT-R
Wheel Diameter = 18" (ADVAN Racing RG1)
Wheel Width = 9.5"
Wheel Offset = +12
Tyre Size = 245/40/18 but will replace with 255/40/18 I think.
Modifications to fit = None necessary but car's been lowered via Tanabe Springs 20mm
Tyres are still 7mm within the guards at front
Tyres are still 15mm within the guards at rear
If interested, you can PM me with E-Mail Address for pics
thought id finally post a picture, 20mm spacers on rear, nothing on front atm
Skyline Model = 1996 R33 GTST
Wheel Diameter = 18" (R34 GTR)
Wheel Width = 9"
Wheel Offset = +30
Tyre Size = 235/40/18
Modifications to fit = None. fronts clear the suspension arms etc by a whisker, no guard issues at all
These are Terry's old wheels (see 2 posts above lol). Cheers Terry :)
^will need to know offsets but since theyre off a r32 gtst it should fit.
any pics of them on the car?
heres the link here for the wheels http://www.skylinesaustralia.com/forums/18...ee-t267980.html
thanks for the help.......
That looks nuts Nisskid. Love it!
I have a 32 GTSt. Guards are rolled and pumped a bit.
I have Advan RS 18x9 +22 with 235/40/18 street tyres. They scrub a little but not too much.
For the track I use R33 GTR wheels (17x9 +30) with 235/45/17 semi's. No scrubbing at all when at the track.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
