Thank you to everyone within this thread that answered my questions and provided info, and ultimately helped me select my new wheels (width and offset)
Here's the end result (minus big brake kit awaiting fitment)
post-81-14227587210603_thumb.jpgpost-81-14227587427646_thumb.jpgpost-81-14227587668173_thumb.jpg
Skyline model = R33 GTS25t
Wheels/Tyres = Advan RZ-DF & Yokohama A050
Wheel diameter = 18"
Wheel width = 9" & 10"
Wheel offset = +35
Tyre size = 235/40/18 & 265/35/18
Modifications to fit = Rear guards lipped.
  • Like 3
Lots of help from various people on these forums before I bought these - couple snaps from this morning
BNR32 RPF1's 18x9.5+15 with 265/35/18
Std suspension, no guard work, guard liners removed.
  • Like 2
attachicon.gifImageUploadedBySAU Community1422758720.057083.jpgattachicon.gifImageUploadedBySAU Community1422758741.831105.jpgattachicon.gifImageUploadedBySAU Community1422758765.964255.jpg
Wheel offset = +35
Same setup I plan to run on my 33! I'm not sure which tire to run though.... I like the looks of the A050. Have you or anyone else have opinions on these tires? Looking for aggressive tread pattern, dry summer, not quite a slick, type of tire. Good with traction hookup but not destroyed in 10k. Car is a street weekend warrior. Not a track car. I'm located in the states but willing to import a set if it's worth it. Been big on BFGoodrich, Nitto, and Yokohama. Thanks in advance for the advice and input!
Whatsisname, car looks great!
FBRacing, thanks mate!
I have used a fair range of entry level club/road performance tyres, drag tyres and semi-competition tyres over the last 15 years, NT555R, RE540S, KU36, RS3, RT615, ET Street Radial 1 & 2, R888, A048, and now the A050.
I've not had the A050s for long enough to give you an idea of expected road mileage, but over 10k (miles) is probably a bit on the optimistic side. It also depends how hard you are on them.
Both the KU36 and RS3 returned reasonable mileage (approx. 12mths or 15-20k klms of mild to spirited road use). The KU36s were the earlier 180 treadwear version, as opposed to the newer KU36 which I believe is 200. The Hankook RS3s were 140.
  • Like 1
  • 3 weeks later...
Hey guys looking at getting a set of Work Emotion CR Kiwami sizes are front 18x8.5 +30 and 18x9.5 +38, anyone got pics of this on r33 gtst s2 and what are your thoughts on those offsets/staggered etc? any help appreciated.
hey man i have the same idea for my r33 gtst, keen on what it looks like before i do it
KU36 are shit. They gained popularity when they were released as they were cheap. Kuhmo then put up the price (and the treadwear) and they are now just a waste.
you can get NT05's for less which are a FAR better tyre, or if you can stretch the $$$ AD08's
I bought some KU36's which had a tread wear of 180. Manufacture date was late last year. From tempetyres for $205ea for 255/40/17. Cheapest I could find on the Nittos was $280ea from Ozze tyres. Treadwear is 200.
treadwear is not standardised. the nitto's are much softer than the KU36's
Last time i bought them the Nitto's were available cheaper. Maybe Kuhmo have dropped the price back
Hankook RS-3 are actually 200 UTQG rated, Hankook revised the rating.Advan A050 is a track tyre, so you'd want to get something like AD08 (or equivalent from other brands, RS-3, Z2 Star Spec, RE-11, etc.)
When Hankook originally released the RS3 their UTQG was 140 AA A - the set I ran on my GT-Four N were stamped 140. The later 200 treadware rated RS3 is exactly the same compound.
Yoko A050s are just fine as a street tyre, on a non-daily... speaking from experience.
Been a while since I used KU36 but they were dirt cheap when I bought them a couple of years back, shitloads cheaper than Nittos! For the right price KU36s aren't bad as a daily driver tyre.
  • 3 weeks later...
Hey guys after reading 20+ pages I'm having a hard time finding anyone with the exact set up as me.
I'm wondering if I could fit 255/35R18 tyres on a set of 18x8.5 +35 D1r's on the R32 GTR. If not there is a 245/35R18 available too which is more likely to fit but the tyres are the same $$ so I figured I'd go bigger if possible. Also my wheels meet the minimum recommended width for both tyres
I currently have 235/40/18 and there is a bit of minor scrubbing on the front right but not the left.
Should I roll the guards and fit the big tyres? the 255/35 have a lower rolling diameter than the 235/40
The car is about 1-1.5 inch down from stock height but I will be raising it slightly with new coilovers in the coming months.
Thanks
    • Just a thought, how come you didn't use a 4D table? So you essentially run 2x fuel and 2x ignition tables, and the table/map switch is handled when there's enough WMI pressure detected. This is mine, but using the flex sensor as the 4th dimension, note the slider at the bottom. Between 0 to 70%, the timing is blended/interpolated , once it goes past 70% ethanol full send
    • Hi guys, after dreaming of owning a JDM legend for 20 years, I got the chance to buy a 1995 R33 GTR.  I live in a small country called the Solomon Islands which is in the pacific. There is no performance car scene here, however 90% of vehicles here are 2nd hand Japanese imports so there is a handful of JDM sports cars here, tucked away.  3 Evo VI’s, 1 180sx turbo, 2 GTO’s, 1 R32 GTR and 2 R33 GTR’s.    Only 1 Evo and a 33 (mine) are active. I’m hoping to set up a club to get these cars back in the road.    I’d known of my GTR for 9 years and always dreamed of owning it. At the start of this year I found it sitting outside a workshop waiting for a respray. It was in pretty bad shape, although running and driving perfectly apart from a big exhaust leak and worn out bushings. My brother in law who is a huge GTR guy came over for a holiday and I took him to see it, he got into my ear and I bought the car 2 weeks later as is.   I’ve had a pretty bad problem with alcohol and weed since 2020 and I really wanted to quit. So I used this as my motivation. I quit everything cold turkey and have been investing all my spare time into restoring this car. It’s honestly been the best experience and has been such a positive impact on my life.  There is no market for these cars here, no parts and no mechanics that can work on them, so if you wanted to sell one it would be pretty impossible unless you found the right buyer. After a bit of negotiating with the previous owner (a good friend) I got the car for $15,000 AUD ($85,000 SBD) which is insane.  I’ve almost finished doing a refresh on the engine, new turbos, spark plugs and split fire coil packs. Also new gaskets and seals, This car had no leaks to begin with, but it’s due now being 30 years old. . Next I’ll be working on the suspension, all new bushings, ball joints, king pins and new coil overs.  Then it will be body work, it has really bad rust in the boot floor, I have purchased a rear beaver cut from my bro which will replace the rusted out one. The car is originally KL0, but was burnt orange when it landed here, then it was resprayed toxic green and then Bayside Blue. I’m probably going to get it redone in Bayside Blue.  I’m super grateful to be able to enjoy this car and couldn’t have done it without my bro Chris from OG-JDM. Looking forward to the future with this car and hoping to get it on the runway at the airport here 😂  cheers fellas
    • Also, it is just about triangularity. The less angle, the easier it physically is to do. Think of the amount of slip you're getting, as how hard you need to push an object. More slip, equals pushing way harder. Then the ramp is how steep the hill is. The Accel is less slip, which means it takes less pushing (less slip) to get it to be able to push apart. However, the steeper sides on the decell means it will take a lot more pushing (slip) to get it up the ramp.
    • It's the angle of the ramp from the vertical. You're measuring from the horizontal. To convert, take 90* minus your angle reference = Nismo Angle.
    • I agree, thus 45 degree is the *max* force one could apply to it. This is similar to what I've seen in uh... simulations... which allow you to play with diff ramp angles. Anything higher (or lower) than 45 degree would produce less force as 45 is the max... triangley.  I would state the 1 way is 90 degree, at least this is how my brain and other ways of explaining it refer to it. 90 degree also effectively acted completely open. I realise Nismo refer to it not as 90 (or 89) but "1". So I'm not understanding the angle on which these angles are based.
