18x9.5+22 255/40 A050s all round.
Would not recommend without serious camber on the fronts, or pumping them hard. Chewed the guard hard on tight corners. Rears were fine.
Are you sure that's 9.5? I know semis are usually a tad wider but that looks more like 255s on 9"
I am looking at this myself as I was wondering if I can get close with 9.5 +27. I have -2.2deg camber at the front, and happy to roll and maybe even flare guards if the price is right to get it done.
As you have it, how close is it from being feasible?
Yeah they are quite large. I think 265 are supposed to sit sort of flush on a 9.5, but mine are still quite bulged.
Update on my fitment. I pumped/flared my front guards and had minimal scraping issues. Running maybe -2/-2.5 deg camber I should have no clearance issues with the current height.
any thoughts on 17x10+38 in the front?
I've already got this in the rear and it sits super flush with 265s and would ideally like a square setup so is this going to work?
obviously going to need some fender work but am i going to smash my struts?
cheers
39 minutes ago, niZmO_Man said:
Pretty sure that'll hit. You can measure it though :P.
not for another couple of weeks, i'm away for work and was hoping to put an order in so i can have them for when i get home  :banana:
looks like i'll just have to chuck the rears on the front and see how she goes, fingers are crossed
cheers
I don't think they will, I test fitted my old rears - 9.5+38 on the front of my 34 with a 15mm spacer and there was about 10mm clearance at most
10" and +38 would be up against the suspension I think
Currently using 9.5 +26 and have about 10mm clearance
that sucks.. not giving me much hope but i'll still give it a crack once i get home.
i found this:
http://honda-tech.com/forums/vehicles-sale-42/f-s-2001-nissan-skyline-gt-t-sedan-3175277/
rpf1's only come in +18 or +38 in 17x10 and that to me doesn't look like a +18.. it sits how my +38's do on the rear. i do however have a coupe not a sedan but surely the guards aren't 20mm wider on the sedans?!
also:
http://forum.jdmstyletuning.com/showthread.php?7362-The-Skyline-Picture-Thread-(non-GTR)/page91
about half way down the page there is the 34 on 370z wheels. it looks as if he is running a square set up of the rear wheels and they are 19x10+30.
Edited by solldogg
i found this:
also:
I can't see the first link being 10" wide all round at +18 offset, they seem to sit within the guard line!
I have a sedan, and the front guards are the same as the coupe, and the rears fit much the same as the front, maybe 10-15mm more clearance
The 370z rims seem to have a fair bit of camber to squeeze them under
Here's how mine fit at 18x9.5 +26, 245's on them. It's as wide as I'm willing to go as its a daily that I like to drive without smashing rims into guards etc
I couldn't get much more under the front with normal camber settings 577cfd20018b1_ImageUploadedBySAUCommunit
577cfe269436b_ImageUploadedBySAUCommunit577cfe37a0802_ImageUploadedBySAUCommunit
  • Like 2
To add to the above post, I have 18x9.5 +27 all round, with 265/35/R18 AD08R (supposedly a little phatter than most) on all 4's. I have -2.2deg of camber at the front and about 1.5 on the rear.
The guards DO need to be rolled/pulled a little to get these to fit. After driving around for a week without this being done there were many bad sounds and long strings of rubber peeling off tyres and such. I don't think this would have been a problem if running 245's like above poster ^----
The rear does tuck in under compression (I have a large amount of squat in the rear of my car when on the fun pedal)
  • Like 2
  • 5 weeks later...
Lads,
I'm sure this has been answered previously but I can't seem to find the exact reply to the exact sizes I'm looking at.
Would i have problems running;
Concept Concave rims at
- 18x10 +20 all round
- 235/40 or 245/40 tyres
- Rolled front and rear guards
If not what would you guys recommend running? They stock 18x9 +20 also, would this be more appropriate for the front and 10" +20 for the rear?
I'm after an aggressive look that wont poke too much and id rather not run staggered but i also don't want to run Mexican spec either!
Sorry for the ridiculously pedantic requests but i can't seem to get the right answer and I'm stuck!
Help would be greatly appreciated!
Cheers
6 hours ago, Snipes said:
Lads,
Cheers
If it's for a 32 GTR, 10+20 will be perfect and can run a decent tyre size like 265
Hopefully someone here is an expert on wheels and offsets and can provide me some "real world experience and advice"
I am interested in acquiring a set of Rota RKR Wheels.
PCD 5x114.3 in 17 inch.
Issue I have is that I currently have a set of wheels that have printed the following 17x10 with ET 15 (doesnt state whether its a + or - ET 15) which fit like a glove! But are shit wheels
I am trying to figure out what my options are in relation to the Rota RKR offsets and what will work.
17x8.5 -10 or 17x9.5 -20
Hope someone can lend some advice on this
  • Like 1
http://www.willtheyfit.com/
I can't seem to work out if a set of Rays LMGT2 17x9+16 with 255/40/17s  will fit on my R32GTR.
I've searched but can't find anything.
Has anyone fitted Rays LMGT2 17x9+16 on a R32GTR without rolling the guards? I'd like to avoid rolling them.
Any help will be appreciated
Andy
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
