Would 17x8 +28 with 255/40/17 tires fit on the front of a R32 GTS-T without rubbing the fender or impacting the suspension?
This question comes from an argument I had with a guy who claims it would be fine. However I want to be proven wrong.
I have a '98 R34 GT-T.
I had some Rota Grid 18x9.5 +35 and 18x10.5 +35 with 235/40 tires.
Fitment looked good but the fronts actually scrubbed on the inside suspension when turning too far. The 235's on the 10.5's were also a bit TOO stretched for my taste.
So I just installed some Work Emotion 11R 18x9.5 +20's all around and kept the 235/40 tires. The fitment looks perfectly flush with the rear fenders but sticks out considerably on the front. VERY aggressive but it DOES fit with stock fenders and doesn't scrub. Sticks out more than I was hoping but I do like it. I don't intend to roll unless I somehow end up scrubbing. I'm running stock GT-R shocks/struts.
Pics:
C225EEB7-3802-4046-AD97-10790DA7A23C_zps
81050FCF-1B5C-40F3-94CB-92EF96C008E1_zps
97E5D908-5A53-46C5-A43C-5771137A6314_zps
Car definitely gets more looks now. :)
  • 3 weeks later...
I'm sure this has been beat to death but after searching and not having luck figured this would be the thread to ask my fitment question on.
Have a 91 r32 gtst
Trying to run 18x9.5 +20 with 265/35/18 on all 4 corners. Is this going to rub like crazy?
Current setup is as follows:                                   17x7 +47 215/45/17 and 15mm spacer up front. 17x8 +47 235/45/17 in back
Edited by Ed.williams5
Hi all
Just bought an r34 gtt. Currently has 18x9.5+22 front and back with 235 to the front 255 to the rear. Tyres are pzero but have 30 % tread left on them, so is basically undrivable in 1st-3rd with 300kw and 885nm.
I have hks coilovers lowered with about a 2 inch gap from guard to tyres. Guards are all rolled too. Currently the front scrubs but I think this is on the loose inner wheel plastic guard (so I don't think I could or would really want to go bigger than 235 as I would need some more camber or raise the car)
With the new tyres im thinking of buying, can I afford to go for a 265 or 275 on the rear or will a good quality 255 suffice?
When I ask can I afford to go, obviously anything is possible, but would anyone have a photo of this so I can see what it would look like?
  • 3 weeks later...
  • 4 weeks later...
Guys please assist. Wheels and I just do not get along. Someone are good at it, I am not!
My r32 gtr is lowered on hks hypermax coilovers. Currently sitting on 17's with a 225 tire.
I want to purchase te37's preferably 18inch and be able to fit a wider tire. Nothing insanely aggressive, but proper looking.
I want 18's because I will most likely be upgrading the calipers and need them to fit. the stock brakes are garbage.
Also, no rubbing issues!
Please suggest.
Thanks
I'm not a noob, promise. Just suck with wheels
Edited by powerdbygarrett
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
