In addition to what Grepin said before re: rear adjustable sway bar, I was also sent part number KBR20-22 (Heavy Duty Sway Bar Mount) but it says it's for a WRX?? The only part that I can figure I use from this kit is the sway mounting saddles which are almost identical to the standard ones. The rest of the kit seems not to fit anywhere?
Bleck
  • Replies 714
Posted Images
Also I have been sent KLC26 (Subaru rr Link Kit h/duty alloy). This also says it's for Impreza + WRX etc. The main components of this kit I can't seem to figure how they fit on the R33. Similar problem to previous post.
Bleck
Bleck
Bleck
Hi, seems like you have received someone elses white pastic bag. They probably have your bump stop and dust cover kit. PM sent to sort it out.
:( cheers :(
hi SK, looking at getting front/rear sway bars and rear camber kit,
just wondering if you know of any reputable company in brisbane to fit them?
cheers
The stabiliser bars are a pretty easy DIY, most of the guys do it themselves. Any decent suspension shop can fit the camber kit. Your local Fulcrum are most likely your best bet, but be aware that they will try and push their products and rubbish everyone else. So they can be a pain to deal with first up, but their work is usually OK.
:D cheers :D
Bilstein Australia have recently managed to tag onto a small production run of R33GTST and R33GTS shock absorbers that was done for the Japanese Bilstein agent. They also managed to have the valving done to our specifications as per the previous Group Buy sales.
These shocks arrived via airfreight today. So there are currently several more sets of R33 Bilsteins available for anyone interested in the Group Buy kit.
:( cheers :)
With regards to the sway bars. I believe it should be sitting on the wheels when all done up. I did mine on the jack stands would this be an issue.
Also have people done the cradle bushes on stands etc or use a proper hoist. Once again ment to be done when sitting on the wheels.
Edited by grepin
Also have people done the cradle bushes on stands etc or use a proper hoist. Once again meant to be done when sitting on the wheels.
Unlike some other cars, Skyline stabiliser bars and their links have full/free rotation, so it is not necessary to do them up with the car on its wheels.
The rear subframe doesn't carry any verticle loads, that is done by the springs. The cradle carries longitudinal and lateral loads. So once again, unlike some other cars, it is not necessary to do them up with the car on its wheels.
:) cheers :)
Hey mate, I want to do a bit of suspension work to my car but on a light budget, I've notice that my castor rod bushes on the front are a bit rooted & I can't lower my car from standard (nope not even a centimeter). The shocks are still pretty good at the moment (car's done only 45,000 kms mainly at low speed in cityscape Japan), so I'm thinking I should invest in some deacent bushes for my entire suspension (or the most important bits at least).
Would you be able to quote me with some costings for these parts?
Also I've heard that you can get bushes for castor adjustment, which is meant to be perfectly legal as opposed to adjustable castor rods, do Whiteline sell these too?
PM sent
;) cheers :mad:
i wanna get hold of the caster kit and rear camber kit, when sending the money to the supplied account, do i just put my username for the description and then send you a pm?
cheers
cheers
Hi Adam, best to send me a PM first to confirm the exact cost.
:D cheers D
1.
Does the caster kit KCA331 improve steering feel? Because I want more feel in the steering. Or am I barking up the wrong tree?
Should l get the sterring rack bushes instead (from super pro)??? Or perhaps both?
2.
Also does the subframe lock increase stress on the factory subframe bushes that get compressed?
3.
I have fairly stiff springs and shocks atm (but not as stiff as say Tein HA), would the addition of anti-sway bars front and rear make it much stiffer.....because it's acceptable at the moment....much stiffer and it would be no good. I would like more roll resistance however.
Thanks...SK you're a champ.
Sorry about the questions I just like to know exactly what I'm getting into when I buy.
Edited by simpletool
1.
2.
3.
Suggestions to your questions follow;
1. Yes, more caster improves steering feel, as well as reducing the tendancy to wander at speed and improving the turn in. Note that the caster kit bushes not only improve static caster but the further improve the dynamic caster as they resist deformation under load.
2. No, the rear subframe alignment kit actually reduces the stress on the standard bushes. They absorb a hreat dea lof the loadings that would other have ot be absorbed by the standard rubber (silicone filled) bushes.
3. Stabiliser bars reduce the roll, that's their job. They do add a little to the bump stiffness, but more than 50% less than would be the case if the roll was reduced the same amount by using stiffer springs. A stabiliser bar connects to both wheels on the same axle. Which means for a given amount of roll 50% is on the outside wheel (in the corner) and 50% on the inside wheel. For a spring to stop the roll it only works on the outside wheel. In fact the higher spring rate pushing upwards on the inside wheel actually increases the roll.
Stabiliser bars are the best bang for buck suspension upgrade you can make.
Hope that answered your questions
:( cheers :(
Hey SK
I know nothing about suspension so I apologise in advance for stupid questions :( , to lower the 33GTST safely and retain a decent ride and good handling do I need everything on the price list or are some things optional?
Hey SK
I know nothing about suspension so I apologise in advance for stupid questions :D , to lower the 33GTST safely and retain a decent ride and good handling do I need everything on the price list or are some things optional?
Sorry I missed the question.
The answer is it depends on how much you want to lower it. Following is the camber correction required for various ride heights;
This is what is usually needed for each height increment, note that all measurements are centre of wheel to guard;
Standard (new) height is 380 mm front and 370 mm rear
360/350 mm needs only the standard rear camber adjusters
350/340 mm needs 1 front camber kit and 1 rear camber kit
340/330 mm needs I front camber kit and 2 rear camber kits
Using lowered springs and standard shocks is covered in this thread;
http://www.skylinesaustralia.com/forums/in...howtopic=103158
Stabiliser bars are the best bang for buck suspension upgrade you can make for improved handling.
Skylines NEVER have enough caster, that's why they wander at speed, are reluctant to turn in and have poor steering feel. Hence the need for adjustable caster (radius rod) bushes.
The standard rear subframe bushes are very soft, silicone filled. They are soft when new and do wear over time until they finally leak. The rear subframe alignment kit supplements the standard bushes, stop the subframe from flopping around and at the same time give some adjustemtn of the rear squat. This allows for improvement in the rear traction.
In summary, I haven't included anything in the Group Buy that I don't think is necessary.
:nyaanyaa: cheers :laugh:
PS; the Group Buy is open until the Bilsteins run out, there is still stock at the moment.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
