Ive got a R32 GTR running standard boost with the standard airbox attached. Im looking to get some more turbo spool noise or induction noise and also make the turbos flutter louder or make some kind of noise when i change gears.
I want to keep the airbox on so is there anything i can attach to the box to make the car sound better ? And i dont want a BOV. Both because i dont want to be defected.
Any ideas ? Is there a panel filter that makes a good spool nice :D
Thanks! Mark
https://www.sau.com.au/forums/topic/85739-turbo-spool-noise-gtr/
  • Replies 52
i dunno about brotec. I once ordered their half replacement full plugin turbo tech ecu from autobarn and the guy there reckons that they don't make that model any more? what's up with that?
I'm interested in the emulator though... group buy?
Thanks! Mark
I have an idea, f**king kill yourself.
