  • Replies 86
well nissan built my car for me :( I just fark it up.
mostly just for burnouts.
hahaha
no, my car is steadily becoming better on track, worse on street. but when i chose my next (track) car it will go back to being a street car.
Me either.
But Seriously - this time round, I am just doing light stuff to my car using quality but value parts.
Eg: $600 Just Jap Cooler, $600 Just Jap Zorst, Jaycar Fuel Computer, $35 boost controller,
I just gotta work out a way to get a cheap turbo :)
well nissan built my car for me :O I just fark it up.
Word. Except my car is so stock I guess we should ask Mr Nissan what its built for because I haven't had much influence.
In the end I want a reliable (hahaha! I kill me!) and responsive street car. I don't expect it to be a daily driver. I want it to be something that I can jump into, find that piece of twisty road, and just have a blast. Were in not few a few issues at the moment that I don't have time to fix, it pretty much gives me that anyway but there is always the endless desire to improve bits and pieces.
Someday I would love to spend some time improving my driving on a track but I think I will select with something more mundance (read: cheaper) for that as GT-Rs seem to cost enough to keep on the road, let alone the track.
I built my car to beat MORGS one day lol
Nar really as a tuff streeter which i can take to the drags....... and one it will work with out having to keep handing over money every 5 mins
Edited by blk180
wilch is your car a white series 2? my sister needs another one for her wedding would you be intersted?
Hey Brett I got one, up in the mtns too if you need one.
Vijay
I just wanna see if a stock gtr can go OK. Well n1 turbs.....but the rest.
And if I can last more than 1 race weekend without a blown motor
And to make give Kel a shot to be the quickest chick on SAU around a track :P (Neil excepted of course)
Brett I heard you car is built for cruising the mountains atm?
DRIFT....fully sideways mate...fully......
hahaha
Ok seriously, drag racing doesnt really float my boat so im trying to build a more track oriented car. Having said that I probably will take it to the drags one day just to see what she can do and if I have the balls take it to a Fatz drift day and throw it sideways.....
oh and a bit of show as well.......yeah im a ricer....
Edited by shonen
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
