blew my gearbox saturday :) (in the cefiro), now i gotta find another asap :woot:
You have to be softer on your changes young man :D
UPDATE: I still have to pull the motor out of the 32 :) so i haven't really progressed any further than last time :(
Having no wheels and no money bites the big one :)
Well an update for me, hole in one of the welsh plugs in the Apollo and it needs a hose kit. Cause i dont have the $700 they want to fix it im now officially car less and thats 4 cars in the drive now that done work :huh:
ROCK BOTTOM meh...
well i pulled my diff out to take the shim that i had put in out because it was to tight. im mate got a bit hasty putting it back to gether and started hitting things with a hammer and ended up braking a sir clip on one of the half shafts. oh thats righ i go a new clip from nissan whent to fix it and hed broken the other on to. so another day waiting for parts. dam it.
Well an update for me, hole in one of the welsh plugs in the Apollo and it needs a hose kit. Cause i dont have the $700 they want to fix it im now officially car less and thats 4 cars in the drive now that done work :)
ROCK BOTTOM meh...
Chin up Ben, things will get better.
update for me,
Car goes back on the rollers will dr drift is over. Not sure if mine gets done tomorrow or monday.
Would of liked to be off on sunday for the dyno comp, but i'm day shift.
Edited by woolls
Cheers mate, pretty happy considering it only has minimal engine mods and a tired old motor! I guess she still has a little life in her yet :wave:
Mods: (RB20DET) FMIC, Bosch 040, Gizmo EBC (14.5psi), 3"Ex + Dump, Pod and an R34 Neo Turbo
dam thats good so you didnt need injectors??? im gessing the stockies would be getting pretty maxed. did dr drift tune it for you? oh nad thats a fair bit of boost i thought you could only run like 12 throught thoes neo turbos. whats it feel like toddy i wish i could go for a ride id like to know what near 200 in a 32 was like.
cheers guys... yeah, pretty happy with it! goes very well, I think it has been tuned a little more for top end as it has a bit more lag but still not too bad due to the turbo.
14psi is fine on the turbo, wouldn't go anymore but it should be fine. This one has steel wheels and holds strong!
Update for my car. I' ve finished pulling off the old intake manifold and turbo manifold and have drained al the coolant out of my block. somehow managed to get coolant down throu the valves. luck the rings were in good condition because i didn't get much fluid in the oil at all. should be all up and running by the end of the week
Well im stuck in 2mind sets at the moment with what i want to do with the 32. First thing first is to pull the motor out and strip it down to see what the damage is and go from there :ninja:
Part of me just wants to get rid of it and be done with it for a while as there will always be time for more cars/toys.
The other half wants me to rebuild it better than before, fit the parts i have and see how much potential it really has :(
205rwks with a turbo, FMIC and dump on 14psi mmmmmmmmmmmmmmmm imagine what it could do with forgies, cams, cam gears and 21psi :happy:
Update for me, got a few bits to try and make me look better at the drift day next weekend :(
Hicas lockbar
D-project tie rods
D-project castor rods
D-project subframe bushes
D-project tie rod ends
D-project lower arm brace
looking forward to seeing how much difference not having HICAS makes
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
