not so bad, you can now buy something that works. HUMM, maybe i should do thesame. LOL.
On another note, i scorred all the gaskets and studs and bits and pices needed for the exhaust manifold repair for $154 all up. YEEHHHAAAA.
Looks like i have sold my snotter :(
damn :ermm::ban:
you can both buy my 33 :O , hasnt missed a beat :w00t:
:O you shouldn't even have to ask what the plan is!!!
damn :ban::(
you can both buy my 33 :ermm: , hasnt missed a beat :w00t:
Still got the turbo for sale though Toff :P
Id love to buy your 33 but i just need some wheels to get around the net few weeks as it is without being fancy!!!
wogs....what was your torque reading on the 25?
at 170rwkw my torque was 550.2Nm !!!
dam thats ship loads. maybe i should bold an old rb30 in my 32 and bolt on a dirty old turbo. surly that would spin the wheels easy.
hahahah, you can feel the torque, well after owning silvias, r32 gtst, r31 gts with rb25, 300TT, vr4 etc etc.....Like the torque of the RB30.
Yeah turbo on, just sorting out the little problems like getting the raditator flushed today and the flywheel machined (damn vibrations in the clutch made it look like I was a retard trying to drive)
LOL. yeah i miss tourqe, the magan has a bit over 400 nM at the front wheels, and that is GREAT, any gear, bag, your away. Skyline, you need to rev it to get anywhere. LOL.
Well done mate, can't wait to see it.
On an up note, found out last night that my FICD, FIRTS IDLE CONTROLL DEVICE solenoid, doesn't work. See if this makes any differance.
plan B, build the bitch up, pronto. LOL.
That requires money and i owe more than i have let alone coming up with enough to rebuild it.
Im going to strip as much off/out of the shit heap as i can and flog it all along with the rolling shell!!!
Then once thats done im out of cars for a while, IM OVER THEM and all there PROBLEMS
Before you get too excited about torque figures remember a dyno set up in power mode (eg rwkw) will not accurately measure torque.
I mean, if the dyno was set up for a torque reading and you got 550Nm then that's an awesome result, but if it wasn't then there is absolutely no truth in that figure. This was a big problem after the dyno day with Dr Drift when everyone started saying "I have such and such Nm", when all their figures were complete rubbish.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
