yeah tires will be fine
spacers are illigal in some states
i wouldnt worry about the 8mm on the rear, just run a bolt on up front
or get the gktech spacers that come with bolt and slip ons to get the perfect offset
Thanks guys for the help, I guess I will look into running spacers on the front rims.(only coz I can't afford 1k for new rims right now)..with the 17x9+38 on the rears I prob have like mayb 5-10mm space between strut and inside tyre wall, so not sure if its worth the extra $200 to shift the rim 8mm outwards lol I guess I will try to find out if spacers are illegal in WA before i do anything , thanks again :)
Ok, so i spoke to my local Ttf store and they suggested that 235/45/17 tyres would be good on a 17x8 rim as on the 9" rim they are stretched and that's bad for traction/handeling in awd? Does offset change if I go down to a 8inch rim? Cheers
  • 4 months later...
  • 4 weeks later...
Ok last night had the best idear and put some 20X11 + 13 on the rear of my m35 axis but even with the 6 deg of camber I got its still going to need a little bit of guard work
Not 100% about using that 11" wide as don't think there is anyway I would get them on the other end
Didnt you say in the other post you have a wobble in rear end. Could tyre width have something to do with it?
Ok ATM I have 225 tires on both the 8 and the 9" wide rim both 45 profile
So if I keep my rolling diameters the same I should be sweet??
  • Like 1
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
