Of course, but most cars and drivers can get away with a shitty cast rim, depending on the design. But our cars are 2T high performance wagon with (sometimes) crazy people behind the wheel. :P
That said, my set of 17 inch drifteks have taken 5 or 6 track days without cracking or damage, even running sticky race rubber. I made sure I didn't hit any ripple strips though...
Ok Scotty, I'm with you.. Honestly, for the next 3 yrs or so, this car is just daily, street only. I'l probably get the newer model then when they are compliance approved.
Also, I don't have a pare $2-3K to spend on wheels so, honestly speaking, I just want it to look sweet and ride nice.
on your previous point about front wheels and offset, can you please be blunt for me... what should the offset be on front compared to rear for wheels to fit inside the guards?
  • 2 months later...
jebus, really, all round?...well that opens up a whole lot of dish options, that makes me kinda happy.
yeah im used to skylines when anything under 25 = mexican.
what is standard rs4s specs?.....sorry being lazy,
it seems they are 17X7.5 +40...... are you sure 18x9.5x12 wouldnt stick out?
sorry im not the best with offsets on the fly.....ok , being lazy again...checked a calculator, +15mm on a 9.5 means the inner clearence will stay the same and the outer will extend out by 50mm...your right, thanks for the help
I'm pretty sure the stock wheels are only 7 wide.
18x9.5 +12 fit perfect on my rs4s at standard height. With some low and a touch of camber they'd fit even better. I was going to upload a pic but I can't on my phone.
The fronts would need a massive spacer 30 0dd mm
And the back for that mater on a rs4s , on my old auto cradle I ran a 9 +14 but a manual cradle is 25mm per side shorter
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
