for reference
17x9 +37 had about 3mm of clearance to stock struts
so i'd say you'd want a 15mm spacer on the rear (about 13mm more inset than the 17x9), maybe 20mm, but then you'll probably be poking out the guards
and as said before, you need the same tyres all round
so stretch 245's onto the 11's or run 265's on the 9's (latter is probably better)
Edited by pipster11
the different rotational speeds
ecu sees rears going faster/slower than the fronts and tries to help you out
Then its welcome to surge city!
Mine was doing when one of my rears was slightly more worn than the other
It's rolling diameter !!! Tyer wear would not be enough to trip it, currently I run staggered sets on all my stagea's but as long as you run close enough to the same rolling diameter you'll have no probs
Example 1 19x8.5 and 19x9 running 235 40 18s all round
Example 2 18x8 with 225 40 and 18x9 235 40
Example 3 18 x9.5 with 235 40 and 18x10 265 35
Plus I've had other sets on the car that have all worked out with no surging . Like I said just get close as with in rolling diameter and you will be right
To be honest i think its fine as long as the rears are bigger than the fronts
100% my atessa gauge was creeping up when on the highway (nearing 10 on the gauge)
I changed 1 tyre and its fine now
Also the car was surging at 100km/h
  • Like 1
I found this - had 2 tyres replaced on the front for RWC and got some serious surging issues - chucked them on the back and its aok
tyres dont need to be the same just the rolliang diameter does :)
Ok so using the pirfect wheel specs for an Rs4S
18X9.5 +12 all round
what tire profile do you recomend?
i will most probably roll the guard lips for comfort, i just want it to tuck in nicely, obviously beinf 4wd the front and rears need to be the same.
might get a mate to fit a 235 on on, see what the stretch is like, still unsure of brand so it will depend.
coilovers arrived otday so gonna drop it and see what sort of cavity im looking at
ok i seem to be getting idfferent information from different wheel calculator sites, can some one help me out with some dimensions.
CII Rs4-S c34
it currently has R34gtt wheels fitted which i beleive are
17X7+40
as they are from a RWD R34 they sit quite far in the guards.
just fitted my BC coilovers and when going over bbumps when the wheel cambers in the rim touches the coilover thread.
static it is a few MM off.
its the rears which are touching on bumps, the fronts are fine.
i am going to use maby an 8-10mm spacer to solve the issue but the new wheels are on they way and im confused as to weather they will foul aswell.
they will be
18X9.5 +12
one site sais i will loose inner clearance and another sais it will gain so im not sure.
Edited by GH05T
The wheels should be stamped with their size somewhere inside them, they usually are. I'm guessing they're +30, not +40 offset. An offset of +40 is usually for FWD cars.
Are you using an online tyre calculator? There are plenty around if you do a Google search.
well they are R34 GTT stock wheels which from searching on SAU seem ot be +40
i am using online tire calculators which is where im getting the conflicting information from.
does anyone know of one which they would trust?
Edited by GH05T
had the exact same problem, but both my rears where bold and my front where 95%, and started surging aroudn the 90km/h mark, and the gauge had about 10% i removed the plug under the dash that brought the 4wd light on and limpt home (130km's)
    • I've searched fairly extensively among Japanese websites but found nothing really like those skirts in your photo. The closest I got was Origin Labo side skirts however they look more 'complete' in that they have a finishing piece or tab at the rear of the skirt so it blends into the bodywork, unlike the one in your pic. For that reason I'd say the skirts in your pic could be adapted from another car and they didn't include that tab piece, or those skirts aren't copied from an existing skirt but an original design. Sorry I can't help out in regard to ID'ing/sourcing them
    • Wonder if JB Weld sponsored the event lol
    • There's a big difference between a car built with millions of dollars in R&D, and someone like yourself taking a normal sporty road car, and making it 5 times more powerful. At the same time, get a modern sports car, and you can turn them up towards the 1000hp mark a lot easier too. Also, give that Lambo another 20 odd runs, and chances are it too may break something.
    • There isn’t really a cheap upgrade here. If someone made a decent, bolt in 6 speed that holds some grunt, it would do very well. The 5 speeds suck. You can put a - OSG 5 speed gear set into it. Ratios are tall so it zaps the “zing” out of it. Had one, busted it. - PPG 5 speed gear set synchro or dog’s. Ratios are even taller. - An overpriced Getrag. Nice to drive, expensive to source now. - A sequential of some sort. Expensive, very expensive. How many times do you pop a 5 speed before you throw the toys out of the cot?
    • Yes, fair call. I don't have any special love for super/hyper cars but it was impressive to watch the Lambo line up against successive skylines without any problem at all.
