im going 235/40 tires, i really didnt want to go spacers, i really didnt.
hoping i take some caber away and run about -1deg and it wont touch under load.
under load now it gains f**king heaps of camber with the stock arms
im so confused, noone with an RS4S with 18X9.5 +12 has had this little clearance. why mine?
i.e.
the issue is that you are looking at an example of a car with stock pogo sticks.
therefore in that example:
- the height is standard, meaning next to no negative camber = more clearance
- standard struts are skinnier than the threaded versions of height adjustable coilovers = more clearance
pete used to run 18x9.5+12 on his rs4-s but had 5mm spacers behind them to reduce the amount of time the inner lip spent hobnobbing the struts
Be interesting to see where they sit on the rears on the out side all spaced out. I will be fun fitting my 10+15 on was hoping to tun a with 10mm spacer .i don't mind running camber so hopefully squeez them in ;)
should be able to tuck them, ill post the clearance with the camber arms and tires so i can load them up properly.
this is what my other wheel did scraping the strut
9.5 does have some width to it though :D
you should be apples, Jase.
my old setup was very similar with the narrower cradle (I was running 18x9.5+0 with a 235/40 and -0.5 degree camber). you won't be wanting any camber with the numbers you'll be trying to feed through the tyres haha
  • 1 month later...
  • 2 months later...
RS-Four autos (whether s1 or s2, it doesn't matter) have a wider rear subframe than factory manuals, so it'd be a tight fit without a fair bit of camber. I've had 18x9.5 +15s on mine as a trial fitment and the rears stuck out around 15mm.
  • 1 month later...
Looking at some 19x8.5 +28 fronts and some 19x9.5 +42. Will these fit? And what tyre recommendations do people have. Not fussed if I have to run a spacer just need to know what size?? Going on a rs4s
Edited by Steve.b
=42 will require 25mm spacers at least to clear your suspension. Personally I was very happy with my 17 x 9 on my lowered suspension - meant I could have some decent tyres (255 40). I have gone to 18s to try to get a little taller gearing but if you run 19s you will have very thin (30 aspect) tyres which are not very street friendly.
Pic shows 17 x 9s (subsequently lowered the front one more circlip groove
Second pic shows a set of Nissan 18s (which I reckon are plenty big enough)I trialled before I got my current CE28Ns:
002-4.jpg[/url]
These wheels were to nice to let up. So I need to figure out what I need to fit them. Happy with a bit of stretch look. And I don't mind buying hubcentric spacers. Just need advice on what size spacers and what size tires to keep the rolling diameter close? Help appreciated.
If you have bought these wheels you are going to have to do some work because I doubt anyone has the same combination of diameter, widths and offset to be able to tell you exactly what you need.
What I can tell you is that getting the same rolling diameter front and rear (I assume you have the Atessa awd) is the hard part - never mind your speedo - that's not that important.
In order to achieve that you will need staggered fitment e.g.
Nitto Invo (which I am using as an example as I have just put some on my car) front 225 35 19 rear 265 30 19. With the spacers needed to clear your suspension the rears at least will not fit in your guards so you will have to undertake some serious modification.
Just read through all pages of this thread over two days.. a lot of the same info.. im after the same set of wheels as someone else has posted on here.. rota grids 19x9.5 +20 (http://pages.ebay.com/link/?nav=item.view&id=130578005418&alt=web) with 235/35 tires. For a 2000rs4s According to this: http://www.willtheyfit.com/index.php?width=215&aspect=50&diameter=17&wheelwidth=7&offset=30&width2=235&aspect2=35&diameter2=19&wheelwidth2=9.5&offset2=20#content
They are 22mm closer to the strut and 42mm more poke than the stock rs4s 17s with the same rolling radius. I dont mind using a small spacer on the rear but would like to keep the front spacer free at least. Preferably want the front and back flush to the guards.. maybe a little poke. Does this seem like a fairly safe bet? Im reading it will just want to be as sure as I can. No suspension mods yet but will be getting bc br coilovers at some point. Seems like (with most things) itll work with some and not others and is more of a trial and error type thing.. Maybe someone in the marion area in adelaide will let me trial fit their wheels? (Pm me if you can). Cheers guys
Edited by c34Florry
Post a car you would like it to looks like. Offset is turning into one of those subjective things. People with scribbley tats and ear vaginas think scraping the road with their subframe and pulling their arches out is mad cool.
While the others with a wife, three kids and a mortgage, living the dream.... might want some more practicality, but still have a decent looking car.
Realistically.
Somewhere between +18 to +30, depending on how much tyre you want to put on them.
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
