im going 235/40 tires, i really didnt want to go spacers, i really didnt.
hoping i take some caber away and run about -1deg and it wont touch under load.
under load now it gains f**king heaps of camber with the stock arms
im so confused, noone with an RS4S with 18X9.5 +12 has had this little clearance. why mine?
i.e.
the issue is that you are looking at an example of a car with stock pogo sticks.
therefore in that example:
- the height is standard, meaning next to no negative camber = more clearance
- standard struts are skinnier than the threaded versions of height adjustable coilovers = more clearance
pete used to run 18x9.5+12 on his rs4-s but had 5mm spacers behind them to reduce the amount of time the inner lip spent hobnobbing the struts
Be interesting to see where they sit on the rears on the out side all spaced out. I will be fun fitting my 10+15 on was hoping to tun a with 10mm spacer .i don't mind running camber so hopefully squeez them in ;)
should be able to tuck them, ill post the clearance with the camber arms and tires so i can load them up properly.
this is what my other wheel did scraping the strut
9.5 does have some width to it though :D
you should be apples, Jase.
my old setup was very similar with the narrower cradle (I was running 18x9.5+0 with a 235/40 and -0.5 degree camber). you won't be wanting any camber with the numbers you'll be trying to feed through the tyres haha
  • 1 month later...
  • 2 months later...
RS-Four autos (whether s1 or s2, it doesn't matter) have a wider rear subframe than factory manuals, so it'd be a tight fit without a fair bit of camber. I've had 18x9.5 +15s on mine as a trial fitment and the rears stuck out around 15mm.
  • 1 month later...
Looking at some 19x8.5 +28 fronts and some 19x9.5 +42. Will these fit? And what tyre recommendations do people have. Not fussed if I have to run a spacer just need to know what size?? Going on a rs4s
Edited by Steve.b
=42 will require 25mm spacers at least to clear your suspension. Personally I was very happy with my 17 x 9 on my lowered suspension - meant I could have some decent tyres (255 40). I have gone to 18s to try to get a little taller gearing but if you run 19s you will have very thin (30 aspect) tyres which are not very street friendly.
Pic shows 17 x 9s (subsequently lowered the front one more circlip groove
Second pic shows a set of Nissan 18s (which I reckon are plenty big enough)I trialled before I got my current CE28Ns:
002-4.jpg[/url]
These wheels were to nice to let up. So I need to figure out what I need to fit them. Happy with a bit of stretch look. And I don't mind buying hubcentric spacers. Just need advice on what size spacers and what size tires to keep the rolling diameter close? Help appreciated.
If you have bought these wheels you are going to have to do some work because I doubt anyone has the same combination of diameter, widths and offset to be able to tell you exactly what you need.
What I can tell you is that getting the same rolling diameter front and rear (I assume you have the Atessa awd) is the hard part - never mind your speedo - that's not that important.
In order to achieve that you will need staggered fitment e.g.
Nitto Invo (which I am using as an example as I have just put some on my car) front 225 35 19 rear 265 30 19. With the spacers needed to clear your suspension the rears at least will not fit in your guards so you will have to undertake some serious modification.
Just read through all pages of this thread over two days.. a lot of the same info.. im after the same set of wheels as someone else has posted on here.. rota grids 19x9.5 +20 (http://pages.ebay.com/link/?nav=item.view&id=130578005418&alt=web) with 235/35 tires. For a 2000rs4s According to this: http://www.willtheyfit.com/index.php?width=215&aspect=50&diameter=17&wheelwidth=7&offset=30&width2=235&aspect2=35&diameter2=19&wheelwidth2=9.5&offset2=20#content
They are 22mm closer to the strut and 42mm more poke than the stock rs4s 17s with the same rolling radius. I dont mind using a small spacer on the rear but would like to keep the front spacer free at least. Preferably want the front and back flush to the guards.. maybe a little poke. Does this seem like a fairly safe bet? Im reading it will just want to be as sure as I can. No suspension mods yet but will be getting bc br coilovers at some point. Seems like (with most things) itll work with some and not others and is more of a trial and error type thing.. Maybe someone in the marion area in adelaide will let me trial fit their wheels? (Pm me if you can). Cheers guys
Edited by c34Florry
Post a car you would like it to looks like. Offset is turning into one of those subjective things. People with scribbley tats and ear vaginas think scraping the road with their subframe and pulling their arches out is mad cool.
While the others with a wife, three kids and a mortgage, living the dream.... might want some more practicality, but still have a decent looking car.
Realistically.
Somewhere between +18 to +30, depending on how much tyre you want to put on them.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
    • I didn't actually try it at the time but a Launch X431 with the appropriate software licenses/upsell will have the ABS bleed function. The Consult II you can still find some old sets of equipment but they're really, really expensive:
    • Well I'll start by saying I'm not an engineer. I am going to go with the KiwiCNC ones.  They are made of 7050 alloy have good fillets and radius.  The material alone is in the order of double the strength and fatigue resistance - Those bolts, once torqued correctly place most of the load at the flat face of the mating surface - the 'stretch' you're talking about through torqueing them up would be far more than the extra stretch 'load' placed on them from a steering input or bump. (in my opinion) so I doubt they would flinch.    - but again "not an engineer".      oh and I don't think stitch welding 7050 is a good idea, likely just weaken the material (from what I read)
