Everything the same as last time except:
Racepace Stage 1 Engine
GT2560-5s
Custom Long Split Dumps
HKS Super Dragger Catback
326.5kw on 'run in' tune with a FAT curve
Will run up some ks and then add Z32 and twin 3inch :banana:
-Forged Pistons (Arias)
-Metal head gasket
-N1 Oil pump
-ACL bearings
-New crank
-Head Work (just general tidy up)
-New belts
-Engine Blue Printed
Vehicle also has R34 N1 Turbo's (approx 6000KM)
Bosch Fuel pump
550 Injectors
Nismo AFM
Larger FMIC
HKS Adj Cam Gears (std cams only)
HKS pod filters
2 cracked spark plugs
301kw at 20psi
also had stock dumps and only a 2 3/4" exhaust
so should see and increase when i get on the dyno with hks dumps and 3.5" exhaust
  • 3 weeks later...
could someone please clarify with a PM if this is ok because it seems somewhat low to me.
had my 1993 GTR dynoed on 4wd dyno 3 months back mods include(all done recently beore dyno): apexi power fc and avcr high boost 14 psi(1 bar), extremely large oil cooler, jasma 3.5 inch cat back exhaust and twin pods. everything else is stock
made 198 all wheel kw and 625 nm of torque...... torque seems good but the kw seem abit low compareing to other gtrs...
please pm with clarification
many thanks jenkies
R33 GTR
Garrett 2860r -5 turbos
RB25 AFMs
Apexi Power FC
Greddy E0-1 boost controller
660cc Nismo injectors
Nismo Fuel Regulator
Bosch 044 fuel pump
Turbo back Fujitsubo Exhaust
290.5kw @ all four.
I'm now going to save for some poncams and cam gears, as I'd like to have full boost a bit earlier (current = 4750rpm), and hopefully be able to put a bit more timing into it to make some more power. I'd love to get 320kw or so, which is max i'd like to run on a stock motor.
Ok got poncams 260/260 9.15mm lift...
I did a before and after run on the same dyno... see dyno sheet attached (green line is new power curve)
Pretty sure there's not too much more I can do unless I build the motor or change turbos.
32 GTR
HKS 2530's
HKS 272 CAMS
HKS DUMP PIPES
HKS MANIFOLDS
HKS S/S FRONT PIPES
HKS SUPER DRAGGER
HKS OIL COOLER
HKS GASKET KIT
HKS SPARK PLUGS
HKS SPRINGS
N1 WATER PUMP
N1 OIL PUMP
N1 CRANK
GATES TIMING BELT
NISMO STRUTS
NISMO SWAY BAR
33 GTR BLOCK
ARIAS PISTONS
EAGLE RODS
ARP HEAD STUDS
KING BEARINGS
TOMIE OIL RESTRICTOR
BOSCH FUEL SUPPLY
EXEDY TWIN PLATE
HEAD SERVICED PORT & POLISH
BLITZ INJECTORS
APEXI POWER FC D JETRO
GREDDY PROFEC B
+ MORE
Made 473hp at 20psi on 36degree day with 51degree intake on a mild tune
Previously made 390hp 22degree 20degree intake with a Garagesauras tune at 10-12psi with loads of timing
New coil packs and cam gears and more aggressive tune should see more HP
car has managed a 11.7 with top mph of 120 in 37degree day
will post dynographs
Edited by monga
R34 GTR V-Spec
Garrett GT2860R -5 turbos
Power FC
HKS EVC Boost Controller
Kakimoto N1 Exhaust
HDI Intercoller 4"
HKS Piping & Pods
Nismo AFM's
Nismo Fuel Pump
Edelbrock Regulator
Sard Fuel Rail
Sard 700cc Injectors
Custom Dump Pipes
STD Cams
STD Gears
STD Manifolds
STD Clutch
STD Internals
Running at 1 Bar in very hot workshop
R34 GTR V-spec
Std R34 Turbo's
Eagle Rods
ACL Race Bearings
ARP Head Studs
JE Pistons & Rings
N1 Oil Pump
GReddy Cams & Gears
GReddy Fuel Rail
Nismo 720cc injectors
Nismo Fuel Pump
HKS Hi Power Exhaust
HKS Dumps
Blitz Filters
Apexi Power FC
Greddy Profec B Boost Controller
Tuned by APC Brisbane
281awkw on 98 Ron Pump Fuel
Edited by EVO Cam
R32 GTR
HKS 2.8L Crank
HKS Rods
HKS Pistons
Nismo Bearings
HKS 272 Cams
HKS 2530's
Ported Head
Tomei Cam Gears
HKS Valve guides
Tomei Expreme Manifolds
HKS Dumps
HKS S/S Front pipe
Trust PE-2 exhaust
Apexi Intake
HKS Piping Kit
Trust 115mm Intercooler
HKS Fuel rail
HKS 680cc Injectors
Spitfire Coilpacks
Performance Metalcraft Sump
HKS Oilpump
ATI Balancer
ARP Studkits
HKS EVC
Trust Oil Cooler
Nismo Twin Plate clutch
Nismo mounts
PowerFC D-Jetro
522hp @ 20psi
Edited by jonn
89 R32 (build # 157!)
Garret GT2860R's
CP's
Tomei steel head gasket
Tomei Headstud kit
N1 oil/water pumps
HKS adj cam gears
HKS fuel reg
HKS split dumps
HKS cam belt
HKS pipe kit
HKS intakes
Bosch 040 intank pump
Power FC D-Jettro
Sard 700cc injectors
3" mandrel bent exhaust
Metal cat
Zetti muff
Blitz i-colour boost control
OSGiken twin plate
STD cams/crank/rods/manifolds
Pile of chrome and Speedflow :-)
Tuned by Pete @ ProTorque Dyno in Brisbane
399.9 awhp (298.2kw) @ 20psi
Slight dramas with injectors and computer are holding us back atm... so I will update with the final figure when it sorted! ;-) But it's a great start!!
Add's Purple 32 GTR
2.6L
Eagle rods
CP pistons
262 Tomei cams
Fantasy manifold
Single Billet Z-P turbo
Custom Fantasy Intercooler
Apexi Power FC
Tuned at PITS on Dyno Dynamics dyno on the Gold Coast QLD
413rwhp @ 10psi, 98 ron fuel
477rwhp @ 16psi, 98 ron fuel
Will update full specs and supply Dyno print out ASAP.
This is what it was before
R32 GTR
86.5mm Arias Forged Pistons
Shot peened rods & ARP bolts
Extensively modified crank,grubscrewed etc: c/w custom pump drive collar
Jun Hp Hv oil pump
Custom 7.5 litre gated sump
Remote oil filter / and 24 row Earls oil cooler
262º degree cams
Vernier cam gears
Grp A Valve springs
JUN Bronze guides
Nismo head gasket
Gibson Motorsport Nismo RS581 Le Mans turbo's
Gibson Motorsport Exhaust manifolds
Ported head & manifolds port matched
HKS actuators
SS equal length front pipes
ARC intercooler
HKS hard piping kit
700cc Sard injectors
Twin entry custom fuel rail
Sard Fuel regulator
Custom 90mm Exhaust & HKS rear can
Modified Apexi pod filters
Custom Aluminium 3.2 litre surge tank
Bosche 044 motorsport fuel pump
Dyno sheets available - 360wkws @ 1.3bar on 96 pump gas
All I have done is replaced the RS581's with HKS 2530's and fitted some very big dumpies
Now makes 418 WKWS at 8200 on 1.5 bar on 98 pump gas
Gday,
Just got my car tuned after being off the road for about 3 years. Ive put an RB26 engine (and an R33 gearbox) in an R32 gtst. The tune is a preliminary one, so ive gotta run the car in and go back in about 1500kms so they can turn the boost up.
The car made 345 rear wheel kilowats on 17 psi and 98 octane. There should be more to come, but after driving it home from Silverwater in the wet, im not sure more power is a good idea in a rear wheel drive application!
The specs are as follows:
R33 RB26 (prepped block etc, compression is 9.0:1)
ARP head studs and rod bolts
General head reconditioning but no porting or polishing
Standard cams
HKS cam gears
CP Pistons 20 thou over
Prepped standard rods
N1 oil pump
Tomei sump baffle and head oil restrictor
R33 gtst 5 speed
Jim Berry modified Nismo 5 puck clutch
Autronic SM4 computer
Autronic boost control
Garrett GT35r turbo with 1.06 turbine housing HPC coated
Tial 44mm external wastegate with 17psi spring
Tial 50mm BOV
600x300x100mm intercooler
Earls 16 row oil cooler
Stainless manifold bought from GCG. Modified with extra support brackets and HPC'd
3.5inch dump, HPC'd and wrapped
3.5 inch Trust exhaust
Walbro in tank pump (255l/hr i think)
Surge tank with Bosch 044 in line (i also used the HICAS lines as fuel lines)
Edelbrock fuel reg and modified standard fuel rail
Ford falcon twin thermo fans with 50mm alloy radiator.
I think thats it.
Just gotta get it engineered and registered now.
Shaun
Edited by Shaun
1989 R32 GTR
Mods:
HKS GT-SS turbos at 17psi
HKS dumps
CP 86.5mm forged pistons & rings
Tomei forged conrod bolts
Apexi FMIC
Apexi front pipes
Turbo back 3" exhaust with 3.5" high flow cat and 4" tip
Tomei type b poncams 260 IN/EX 9.15 lift
Tomei adjustable pulley set
R33 GTR long nosed crank
SARD 700cc injectors
HKS Pods
Nismo AFMs
Nismo timing belt
Nismo fuel pump
Splitfire ignition coils
Tomei 1.2mm metal head gasket
Tomei 1.5mm oil restricter
N1 oil pump
Tomei sump baffle kit
GReddy oil cooler
GREX oil filter relocation kit
Apexi PFC
348.5rwkW @ 17psi tuned by Martin Donnon at Willall Racing 3.3.08 on BP Ultimate 98
Edited by writeoff
  • 5 weeks later...
Now making 380 rwkw on 18psi with slipping clutch.
Car is now running Haltech E11V2 with anti-lag, upgraded fuel system and upgraded coils also just dialed cam's correctly after finding out exhaust cam was advanced a tooth, waiting for re-tune. Should make 400rwkw on same or 20psi boost. New ORC triple plate clutch from CI Performance just installed.
Tuning done by Adam at JEM (Just Engine Management)
R32 GTR
N1 block,
87mm Tomei pistons,
Tomei rods,
R33 crank,
Tomei cams
HKS valves, springs and guides,
Trust T88-34D
720cc inj,
Power FC
Z32's
4" exhaust
Power extreme FIC,
Tomei fuel rail,
Nismo fuel reg,
1 x GTR intank pump, 1 x Bosch 044 pump with surge tank,
446 rwhp at 8,000 rpm on 1.3 bar boost on 98 ron.
Edited by mrchams
****UPDATE****
problems sorted, retuned, my GTR now makes 424hp@19psi on pulp.
Mild tune for now to assess engines health (it was swung together before I owned it) and then we will lean on it for big numbers. But there is plenty of headroom left in it! :D
Now to the drags I go!! :(
Engine Mods:
N1 24U Block
TOMEI Forged 86.5mm Pistons
Pauter Forged Rods
TOMEI Gasket Kit 1.2mm 87.0mm bore
TOMEI Procams (270 x 10.8mm)
TOMEI valve springs
TOMEI Cam Sprokets
Nissan Bearings
ARP Rod bolts
JUN Valve guides
ARP Head Studs
TRUST sump extension
JUN High Flow Oil Pump
N1 Water Pump
HKS 2835 52t Ball Bearing Twin Turbos
CES Ceramic coated Dump Pipes
HKS Pod Filters
APEX'i Power FC
APEX'i Dual N1 Exhaust
2x Z32 Airflow Meters
ARC 100mm Front Mount
ARC 16 layered oil cooler kit
ARC Alluminum radiator
Greddy Profec B Spec-II Boost Controller
Nismo fuel regulator
Nismo Fuel Pump
Denso 650cc Injectors
Spitfire coils
522hp (390kw) @ all 4 wheels... 26psi, 98ron.
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
