Been meaning to post this up for a while now.
1998 R33 GTR
Race Pace Stage 1 Engine
Tomei cam gears
Garret 2860R-5
HKS GT Spec Intercooler Kit
Apex pods
Nismo cat back exhaust with De-Cat
Running ~ 1.2 bar
Everything else is stock standard
Probably only about 270rwkw, as the run would have been done in 3rd gear and not 4th as the standard ECU is still running the show.
ported head matched manifolds
jun guilds stano vavles
stock cams
stock cam gears and springs
baffled sump oil restrictors in the block cam cover plates
jun collar and oil pump
acl race bears mains and big ends
rev rods
cp pistions
1.3mm metal head gaskit
metal inlet manifold gaskits
pfc
stock cooler
stock inj stock fuel pump
stock air flow meters
stock dump pipes
front pipes 3 inch cat 3inch exhuast and cannon
stock turbos
os giken twin plate clutch
eboost 2 set to 13psi
262rwkw!!! 351hp
since the sard 720cc inj sard intank pump
greddy hard pipe kit
gt2860r5s
16psi 400.6hp
now need new coil packs re wire the fuel pump and tuned for more boost
Got mine tuned yesterday. Couldnt push the it to hard as unfortunatley the stock fuel pump isnt playing the game and running out of puff allready, just old age i think.
Autech 260RS stagea
Arias Pistons
Eagle Rods
Trust 264 deg cams
MHG
Balanced throughout
N1 pumps
Tomie oil restrictor and sump baffel
stock cam gears
stock dumps
2860-7's
HKS front pipe and catback
Stock fuel system
Stock FMIC
HKS magic mushrooms
PFC
Stock AFM's
Turbo Tech bleed valve
304AWHP @ a bit under 10psi
car is very responsive.
Need to get a new pump and go for another tune, then start saving for injectors (damn yen)
R32 GTR 85XXX kms
Power FC (Tuned by Mark tillbrook)
GT2860 -7s
700cc injectors
R34 GTR vspec Fuel pump
Stock AFMs
Cat back Exhaust
Made 285kw @ the rears on 15 psi
Need to get a full exhaust system done.
Edited by joeleo87
RB26DETT
Garrett GT2560R 300HP Ball Bearing Turbochargers
750cc Injectors
Apexi Power FC Pro
Apexi AVC-R
Tomei Pon Cams
Cam Gears
HKS Valve springs
Tomei Oil Restrictor
HKS Sump Baffle
Nismo AFM's
Cometic MLS head gasket
Machined and ported head
N1 Water Pump
N1 Oil Pump
Wiseco Forged Pistons
Eagle Con Rods
ARP Heat Stud Kit
ARP Main Stud Kit
Ogura Racing Clutch Twin Plate
Bosch 044 Fuel Pump
Sard Fuel Reg
Splitfire Coils
340kw atw @ 22psi
94 r32 gtr
garret 2860-5
cp piston eagle conrods ect
custom dumps
3inch straight through
nismo fuel pump & afm
sard 700cc injectors
Tomei 260 deg / 9.15mm lift cams+ cam gears
power fc
hks intercooler and piping
sard fuel reg
profect b boost controller
running19psi
made 332awkw
Edited by tristo
  • 3 weeks later...
Tomei Crank
Tomei Rods
Tomei Pistons
Tomei IN 260 10.85 / EX 270 10.85
PnP head
T04z
1.7 Bar
HKS F Con V Pro
A'PEXi 100mm exhaust
2 nismo lift pumps
2 Bosch 044 externals
800cc Sard
3.5 bar @ idle rail pressure
600*300*110mm FMIC
2 fuel coolers
Nismo Plenum
(and a sh!t load more but that's the main stuff. If people want a full list I will add)
502kW at all 4
camsdialeddyno.pdf
Cams dialed in now, comparison of before and after graphs, blue latest, red perfect tune but with cams set on 0,0.
for recap,
Stock bottom RB26.
tomei ponB's
GTSS
EVC6
mines stainless pro front pipes, 3.5 inch kakimoto mega N1 rear, tomei manifolds
HKS extension kit,
PFC djetro
436.7 rwhp
Edited by R33GTRKid
R32 GTR
Mystery motor built in Japan
Oil relocation system with oil pump, cooler etc
N1 Fuel Pump
Sard injecters 700 (i think)
PFC
N1 Turbos
HKS Exhaust
Heavy duty clutch (not sure on brand or type)
Blitz intercooler
Apexi AFM and intake
tested and tuned at 1.2bar
235awkw
GTR34
2*T517Z
800cc injector
AVCR
PFC+Z32AFM
Nismo intercooler
Nismo oil pump
Nismo fuel pump (its limited the power, need better fuel system for more power)
Nismo full 3" exhaust + cat(need get 4")
Nismo piping
Apexi super suction kit
turbo smart fuel reg
tomei cam gear in&ex
tomei camshaft both 256 i think.
forged piston, rods
1 bar 270kw
1.3 bar 312kw
R34 GTR V Spec
Turbos
HKS GT2530 x 2
Support
HKS I/C Piping kit incl intake pipes with K&N Filter
HKS Fuel Rail, 680cc Injectors, Fuel Pump and Regulator
Tomei PonCam 260/9.15mm
HKS Cam Gears
Tomei Expreme exh manifolds
HKS Dump Pipes, Front Pipes and Exhaust incl. Metal Cat
Apexi Power FC D-Jetro
HSK EVC V
N1 Water Pump
HKS Twin Plate Clutch
Splitfire Coil Packs
Power
441.9 rwhp @ 17.5-18psi - tuned for as much response and mid range as possible
R34 GTR
Trust 2.7ltr
Willal Head CNC
Holinger box
Hypertune 90mm tb plenum
GT3037s twin kit
Motec M880
535KW at wheels PUMP 1.8bar
575KW at wheels VP109 1.95bar
Motor SOLD - New motor being built
Will post output from new combo soon
OS Giken RB30
Jun "Big" Head
T88H-38GK
Edited by OS30GK
R32 GTR Nismo
Std Nismo turbos
Nismo grounding kit
Std dumps, Bee*R front pipe, metal race cat, kakimoto cat back
std internals
Jun cam gears set to 0
Sard fpr
044 fuel pump
PFC
Blitz boost controller
everything else standard
311kw atw 19psi
Dyno update
-My innovate wideband needs to be calibrated....when I recorded 11.5 afr it was 10.5
-I had the gain too high on the boost controller and it crapped itself at 4400
-I tuned the power fc with my datalogit so it looks like I have some more work to do.
-the 4" Arc Ti exhaust sounds like an animal!
engine mods
-new long block from Nissan
-td-05-16g's in stock housings
-stock injectors and afm's
-trust dp
-3" stainless decat
-4" Arc Ti cat back
-Blitz sbc-id3
-power fc
-20% toluene mix for the dyno
I have new Z32 maf's and 1000cc Rc injectors waiting to go in after I upgrade the turbo's to something else.
R34 GTR V Spec:
* HKS Front pipe, HKS rear pipe with Hi Power Muffler, Hi flow cat
* Garrett 2860R-5 Turbos
* HKS SPL full piping kit with HKS super power flow pods
* Nismo Fuel Pump
* Turbosmart fuel regulator with pressure gauge
* Hypertune Billet fuel rail
* Siemens 610cc Injectors
* OS Giken Cam gears
* Nismo twin plate clutch
* Vipec V44 ECU
* Tech Edge Wideband AFR controller
* HKS EVC6
388 All Wheel Horsepower @ 1.2 Bar (289 All Wheel Kw @ 17.4 PSi) on Insight Motorsports Dyno running 19 inch Volks.
    • When: 5 & 6 September 2025 Where: Sydney Motorsports Park Join SAU NSW at World Time Attack Challenge 2025 at Sydney Motorsport Park. Plans will be finalized closer to the day, but make sure you lock in the days in your calendar now!
    • When: 9th August 2025 Where: Meet details to follow, budget half a day for just the museum part of the cruise, or a full day if you want to come up the range with us after! Join us for a cruise to Albion Park to visit the Historical Aircraft Restoration Society Aviation Museum for their August open Tarmac weekend. Walk around the hangers and see these amazing classic aircraft up close. After a two hour break to look around you are welcome to join us in heading up Macquarie Pass to the Robertson Pie Shop for a bite to eat. After a bite we will head back down Jamberoo Mountain Road before returning to Sydney. Full details to follow, for now lock in the dates into your calendar!
    • This is a school night cruise! Join us for a mid week night cruise up the Old Pac. We will stop at McDonald’s in Gosford for a quick break then come back the same way. Date: Thursday, 26th June 2025 Meet Location: Cowan Truck Stop (Pacific Motorway - Refer to Map) Meet Time: 7:30pm for a 8:00pm departure Destination: Gosford McDonald's (65 Pacific Highway, Gosford West) Map: https://maps.app.goo.gl/wi7jcuGxpJsoKtJB8 This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave.
    • Join us for an epic Saturday at JDM Festival! We'll kick things off with a feed at Big Fat Greek Campbelltown to fuel up with some delicious eats and good vibes. After the feast, we’ll cruise over to Sydney Motorsport Park for the main event: JDM Festival! Please note: space is limited and depends on the number of SAU NSW members who commit to attending. To help us plan accordingly, we appreciate your timely registration. Date: Saturday, 14th June 2025 Meet Location: Big Fat Greek, 2 Rennie Rd, Campbelltown NSW 2560 Meet Time: 2:30pm for a 5:00pm departure Destination: Sydney Motorsport Park, Ferrers Rd, Eastern Creek NSW 2766 Important Information: Spots are limited and will be allocated on a first-come, first-served basis, with priority given to current financial members. REGISTER YOUR INTEREST HERE This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • You'd want to cap off the re-entry back into the dump too. Just something flat that can be held on by the Vband.
