This thread was started some time ago but read till end for follow up.
I here this expression frequently, some times in different context .
What does this mean exactly please?
How do you do it?
Why is super gromet style metal head gasket not sufficient? Or is it. <_<
An O ringed block will have a groove machined around each bore and a steel ring pressed into the groove. This will apply significantly more pressure to the gasket to prevent it blowing out under higher internal combustion pressures.
It is often accompanied by a matching groove in the head to further trap the gasket. Block O ring (if yoou are getting machining done) costs less than a metal gasket including the OEM gasket.
Wouldn't mind a wiki set up with technical terms like these.. great description GTRGeoff wasn't too sure of it myself..
Good idea :) Wiki's are useful and we can tell everyone to search the wiki instead of the woeful forum search.
Good idea :( Wiki's are useful and we can tell everyone to search the wiki instead of the woeful forum search.
What do you mean woeful?
There is nothing wrong with the search functions of this forum.
I use it so often and within 5 mins tops ive found what i was looking for, or enough information to make more questions.
Well make one yourself, maintain it yourself and submit it to the Admin
(i guess thats where the idea stops eh?)
Here's a link to a wiki that i was playing around with a while ago, dont have a lot of spare time at the moment though. If we can get enough useful info on here i'll register a proper domain name for it. Most of the info can be cut and pasted from other places on the net.
Skyline Wiki
This is not something for backyard mechanics, but a specialised engine machine shop will have no problems sourcing and fitting.
So is it better than a quality metal grommet style gasket or simply cheaper because one can use a cheaper gasket ?
I assume that one could not use a metal gasket if it hasbeen O ringed?
Skyline Wiki
Fatal error: Call to undefined function: getspecial() in /home/content/b/3/3/b33st/html/wiki/index.php on line 97
:lol:
If you wanna talk about setting something up, im more than willing to help with it all, simple enough to do id imagine.
Just gotta have the interest.
People use both, as posted above, but it depends on your power requirements.
The gaskets ability to hold pressure is the combination of its own structural strength at its weakest point, the clamping pressure of the head and head bolts, the evenness of the clamping pressure and any ancilliary aids to retention such as O rings or W rings. I've used an RB30 gasket modified to fit the RB25 at a time when RB25 parts were scarce and I had to move the car from Canberra to Melbourne and eventually it just pushed the gasket sideways into the water gallery. Blowing the head gasket could be from displacement, warping of the head, corrosion/poor preparation or a combination of those. The rings help prevent displacement.
Edit: as for is it better than the super grommet gasket, that is using stock gasket and O ring, I don't know. You would have to be producing some massive power for it to have to need better, and so cost would be little inconvenience and you would use the best of everything.
Thanks  for your oppinion Geoff,
i understandall what you said . My main piont and question is that many people use the term O ringedblock as if it is something super special  where i now see it as simply an cheaper alternative( in the long run) than an expensive quality gromet style aftermarket head gasket.
I will run with my Tommie super grommet and new ARP studs for now.
Thank you all for yor input.
Dave, A quality metal head gasket is upto just about anything you want to thro at it with most big power cars using them but the Oring adds that much more reliability in massive boost cars tuned to the limit like you plan for yours. When using an Oring on a metal head gasket it can take days to settle needing to be retensioned a few times before startup and then retension after its been run.Many 1000+hp cars run the metal gasket alone without trouble but at about $130 to Oring it wont add much to a major buildup and does seem to help if you overheat your engine and leaking after overheating seems to be the only weakness of metal gaskets.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
