  • Replies 315
wow....alot of respect for your build mate....its not only painful to fork out the $$ but more so in the time it takes to get it together and on the road!!
but its worth it, at the end of the day u'll have an awesome setup!!
cant wait to see the figures it pumps out...its going to be a beast
Looking good Brad. Well done. Make sure you post up the graphs when she hits the rollers.
I thought my Stagea was nice, looks like a piss ant POS next to this.
ken
Edited by RBNT
Very nice conversion, may I ask what sort of money to build just the motor? (Pm if you like).. And why you went the JUN 2.7lt? And say not the Tomei 2.8lt? Or even HKS for that matter.
I'm currently looking at the Tomei 2.8lt, but are still in heavy research mode until my gtst goes to free up money, so I would love to hear pro’s and con’s and everyone’s opinion.
Yeah im interested in some info too, alternatively, did you look into buying say a complete engine from Tomei/mines etc brad?
yes im leaving the standard harmonic (at the moment) which limits the rpm to under 9k but for 500rwhp i wont need to rev it that hard, and the engine parts i choose because they were offered to me second hand, and i want the revving nature of the 26 to remain, as ive had a rb30 and it was a truck engine in comparision (slow reving), but i've explained it all on page 1 and 2 of the thread, and cost of the entire engine and external parts, plus fuel system, ecu, and everything to make the power is over 40K if i bought the bits new, and ive spent over 30k in reciepts, and thats JUST PARTS, NO labour. (cause i saved 10k on the second hand bits, though they were unused and still in boxes).
now u can see y im abit anxious about the build :rant:
crank is limited to 11k for safety, and 13k rpm for extreme applications i've been told.
im abit annoyed i've spent soo much and only want 500rwhp at the moment as i've gone total overkill, and coulda used stock parts in the build, but i always want room for more power, and next target is the t04z's limit which is 700rwhp, and then i might get another larger turbo to push it even harder and get above 700rwhp. The engine combo is rated to 800-850rwhp or so with a trust t78 by the JUN head guy. or over 1000rwhp with a t88.
I cant imagine how hard it would be to tune an engine like that on the dyno. one little bit of knock that you cant even hear and BANG its blown up before you know it...
What im saying is that it takes serious tuning skill and knowledge to get a beast like that running to its potential...
Cheers,
Matt
PS - cant wait to see it roaring down the strip :)
Edited by MattSR
So what are you going to make the limiter assuming you change the balancer?
9500rpm?
And yeh you better have alot of faith in your tuner!
not sure, as the gearbox wont shift above 9k rpm and i need oversize pulleys to prevent blowing the air con compressor up and to slow down the power steering and water pump (n1 which flows less already so might get hot in traffic with an oversize pulley and cruising speeds)
i think the need for over 9k rpm wont be very often as it is going to be a street car and not a drag/track car, so i need it reliable in traffic as much as possible, i have another daily driver, so wont be drivin it more than 1-2 times a week for cruises on weekends, or maybe the occasional thrash after work :P
the tuner i am using, does race/rally cars, and high power street cars, currently his best hp is just under 700hp at the wheels from an evo 6 i think (2L turbo)
just sorting all the fuel lines at the moment, and god damn they are pricey :P
spent $400 on turbo braided lines for water and oil
another $350+ on fuel lines and fittings
and i still havent got everything yet. B)
cheers
Brad
Just a quick question are you feeding your fuel rail from both end with the return from the centre, as i can only see feed on the front?
pete
yes it has twin feeds one from each end and then the return in the centre :)
its a Sard fuel rail
I assume controlling it will be something like the silver Stagea a few minutes into this video clip http://video.google.com/videoplay?docid=-8...3&q=Skyline+GTR :(
Thats stagea is nuts.... Cyrus would like this....
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
