  • Replies 315
wow....alot of respect for your build mate....its not only painful to fork out the $$ but more so in the time it takes to get it together and on the road!!
but its worth it, at the end of the day u'll have an awesome setup!!
cant wait to see the figures it pumps out...its going to be a beast
Looking good Brad. Well done. Make sure you post up the graphs when she hits the rollers.
I thought my Stagea was nice, looks like a piss ant POS next to this.
ken
Edited by RBNT
Very nice conversion, may I ask what sort of money to build just the motor? (Pm if you like).. And why you went the JUN 2.7lt? And say not the Tomei 2.8lt? Or even HKS for that matter.
I'm currently looking at the Tomei 2.8lt, but are still in heavy research mode until my gtst goes to free up money, so I would love to hear pro’s and con’s and everyone’s opinion.
Yeah im interested in some info too, alternatively, did you look into buying say a complete engine from Tomei/mines etc brad?
yes im leaving the standard harmonic (at the moment) which limits the rpm to under 9k but for 500rwhp i wont need to rev it that hard, and the engine parts i choose because they were offered to me second hand, and i want the revving nature of the 26 to remain, as ive had a rb30 and it was a truck engine in comparision (slow reving), but i've explained it all on page 1 and 2 of the thread, and cost of the entire engine and external parts, plus fuel system, ecu, and everything to make the power is over 40K if i bought the bits new, and ive spent over 30k in reciepts, and thats JUST PARTS, NO labour. (cause i saved 10k on the second hand bits, though they were unused and still in boxes).
now u can see y im abit anxious about the build :rant:
crank is limited to 11k for safety, and 13k rpm for extreme applications i've been told.
im abit annoyed i've spent soo much and only want 500rwhp at the moment as i've gone total overkill, and coulda used stock parts in the build, but i always want room for more power, and next target is the t04z's limit which is 700rwhp, and then i might get another larger turbo to push it even harder and get above 700rwhp. The engine combo is rated to 800-850rwhp or so with a trust t78 by the JUN head guy. or over 1000rwhp with a t88.
I cant imagine how hard it would be to tune an engine like that on the dyno. one little bit of knock that you cant even hear and BANG its blown up before you know it...
What im saying is that it takes serious tuning skill and knowledge to get a beast like that running to its potential...
Cheers,
Matt
PS - cant wait to see it roaring down the strip :)
Edited by MattSR
So what are you going to make the limiter assuming you change the balancer?
9500rpm?
And yeh you better have alot of faith in your tuner!
not sure, as the gearbox wont shift above 9k rpm and i need oversize pulleys to prevent blowing the air con compressor up and to slow down the power steering and water pump (n1 which flows less already so might get hot in traffic with an oversize pulley and cruising speeds)
i think the need for over 9k rpm wont be very often as it is going to be a street car and not a drag/track car, so i need it reliable in traffic as much as possible, i have another daily driver, so wont be drivin it more than 1-2 times a week for cruises on weekends, or maybe the occasional thrash after work :P
the tuner i am using, does race/rally cars, and high power street cars, currently his best hp is just under 700hp at the wheels from an evo 6 i think (2L turbo)
just sorting all the fuel lines at the moment, and god damn they are pricey :P
spent $400 on turbo braided lines for water and oil
another $350+ on fuel lines and fittings
and i still havent got everything yet. B)
cheers
Brad
Just a quick question are you feeding your fuel rail from both end with the return from the centre, as i can only see feed on the front?
pete
yes it has twin feeds one from each end and then the return in the centre :)
its a Sard fuel rail
I assume controlling it will be something like the silver Stagea a few minutes into this video clip http://video.google.com/videoplay?docid=-8...3&q=Skyline+GTR :(
Thats stagea is nuts.... Cyrus would like this....
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
