  • Replies 188
Posted Images
  • 3 months later...
  • 3 weeks later...
  • 1 month later...
details of CAMS licenses are over here: http://www.cams.com.au/content.asp?PageID=...&ObjectID=2
You can get an L2S Junior license but I am not sure what conditions are attached, you should contact your CAMS state office and ask.
Road drivers license doesn't matter at all :)
  • 2 months later...
Hey all,
I hold a National Rally Licence, and have used it to compete in everything from club level motorkhana's, right up to rounds of the Australian Rally Championship.
Over a L2S, its basically a couple of observed driving tests, an online test, and about $150! :huh:
Nothing too difficult! :)
  • 1 month later...
C3 has been replaced by PC (Provisional Circuit), the NC (National Circuit).
To upgrade to PC you need to attend a flags lecture and pass the Observed License Test (OLT). These are run by most driver training places in conjuction with their advanced or race driving courses, and also on the practice day before most race rounds. You also need to pass a medical.
To upgrade PC to NC you need to be observed by the clerk of course at 6 race meets in 12 months driving to an appropriate standard.
But you don't need PC for anything unless you are looking at doing full on circuit racing, L2S covers all supersprints, drift days, hillclimbs etc. PC and NC are $350ish a year instead of 80 for L2S
  • 4 weeks later...
  • 3 weeks later...
I'm interested in getting a CAMS licence but unsure of any CAMS-affiliated club...
Which licence is best for me to start off with (2NS or 2S)? ..or can I jump to a higher licence? ..or start with a lower licence?
Help?! Anyone??
Thanks in advanced.
Help?! Anyone??
Thanks in advanced.
i think sau is cams affiliated yeah?
if not where are you from? there are many clubs all over the place.
and you want a L2S to start off with 2NS is non speed.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
