  • 1 month later...
94 R32 GTST RB20DET
Stock motor
Stock turbo
Stock Injectors
Stock ECU
3'' Cat back exhaust, Not turbo back
FPR
Walbro Pump
Fresh fuel filter
Boost Controller
Hi Boost 14
Lo Boost 10
Car was running really rough before we put new pump, Filter and reinstalled the FPR correctly and was running very rich,
Took it to our tuner who could only add some timing into it and we ended up getting,
159.8kw on the tuners dyno on the thursday and 232hp on powercruises dyno on the saturday
New upgrades coming in the new finacial year
Nistune
kkr380
Deatschuwerks 650c injectors
Turbo back 3' Straight pipe
Looking for 220,240kw atw,
  • 2 months later...
hey all finally had my car tuned and heres the results so far
standard rb20det
kinugawa td06 sl2 20g
tial 38mm external gate
600cc injectors
nistune
3" exhaust , straight pipes
bosch 044
front mount cooler (china spec)
fuel pressure reg
apexi avcr
plazmaman copy plenum
made 321hp at the wheels on 17 psi on 98 octane
might wind the boost up further or go to e85 but ill see how this setup goes for the moment
Edited by Supreme87
  • 5 months later...
Stock Rb20det Engine
Nisstune Kinugawa TD06-20g Sl2 8cm Anti surge
38mm tial external waste gate welded to a flange off the Rear housing
Stock exhaust & Intake manifold
600cc injectors
255lph Fuel Pump
z32 AFM
Front mount & 3" exhaust
220Rwkw on 18psi
  • 1 month later...
200SX EUDM swapped S13
RB20DET STD internals
S13 airbox modded to fit a Z32 MAF and with the R32 GTS-T air inlet which is about 33% percent larger than the S13 one and a paper filter in it
Custom forward facin plenum made by an australian drifter with very short runners and no stack
Kinugawa highflow RB25 turbo (garrett stage 3 wheel and cast 20g compressor wheel)
Stock exhaust manifold
3" down pipe Clarkson fitted to avoid the steering column
3" resonator to 3.5" catback (apex'i hybrid megaphone)
Chinese FMIC
Deatschwerk 440cc injectors (flow matched @458cc)
Nistune on STD ECU
14psi/0.95b peak on the actuator
PULP 98
Very tired gearbox
My Z32 maf died on me the morning I had to put it on the dyno, I made 40 km on limp home borrowed a mate's MAF and went to the dyno 200km away. With his MAF I run richer and felt a slight decrease in power up top.
Final result :
197 rwkw/ 221fwkw
320 Nm.
The engine is not knock limited, in fact there is no knock limit at this boost, I only lose power with more timing. I suspect the engine can't breathe efficiently enough to put more kw to the wheels.
Edited by R_34
  • 3 weeks later...
  • 1 month later...
Couldn't handle the E85 price rises. Needed a new timing belt so got Jez too do that and retune the cat back onto Premium 98.
Same parts as the tune below except a while back replaced the shitty old catback with a varex to an Apex Super Megaphone exhaust, super quiet, much better flow I think. This tune got 218rwkw @ 19psi, 196@ ~ 14psi.
Just got the car back from Jez, last tune pulled 201rwkw on Pump 98 with
Hypergear RB20 Highflow Turbo
FMIC
3" Turbo back exhaust
555cc Nismo Injectors
Walbro 255lph
Splitfires
Stock air box with K&N Panel Filter
Nistune ECU
Greddy Profec B II EBC
Since that tune I replaced the cat with a Venom 100cpi stainless cat, and on his dyno it pulled 216rwkw on the last of the 98 in the tank
Then got tuned on United E85 and on 15psi ran 208.5rwkw and on 20psi 242.8rwkw, but hitting the limit of the fuel pump. Awesome result!
Edited by cherring
  • 4 weeks later...
180sx RB20
Stock unopen RB20DET
Stock Cams
Cam Gears
Splitfire Coilpacks
High Mount Manifold (Cheap Stainless)
Hypergear ATR43SS1PU
Stock Intake Runners
Fake Plazmaman Forward Facing (cut/moved throttle body for tubs)
Plazmaman Front Mount
GTR 444cc Injectors
Walbro 255LPH
Tomei FPR
Adaptronic Plug In ECU
Apexi AVC-R
3" Turbo Back
No Cat
38mm Wastegate
98 Octane
16psi: 210.4kw
20psi: 237.2kw
Tuned thanks to DVS Jez
Edited by green180sx
  • Like 1
  • 1 month later...
Stock RB20det unopened, no metal head gasket
GTX2863 turbine
Top mount exh manifold
570cc GTR R35 injectors
Z32 AFM
255 lph Walbro internal fuel pump
Ron97 fuel (we only have 95 and 97 here)
Works FPR set at 4 bar
FMIC
APEXI Power FC
Car tuned on Dynodynamics at 1 bar/ 14.5 psi boost.Output is 207hp / 155rwkw
What you guys think, shouldn't i be getting at least 260hp on this setup ?
Is it that much of a risk to go 18psi on boost without a metal head gasket..?
Your honest opinions are very much appreciated
  • 2 months later...
RB20DET Silvertop
Standard Internals
Cut and shut standard plenum to ffp
3" straight through exhaust with twin tips
FMIC
Z32 AFM
Nistune board
Helps Metalworks top mount manifold
38mm Tial MVS venting to atmo.
Kinugawa TD05 18g 8cm rear
550cc Injectors (BP 98)
Bosch 040
adjustable fuel pressure reg.
Tuned By Garage7 on hub dyno on 21psi off the wastegate @240kw
  • 3 months later...
RB20DET silvertop stock
TD05-18g 8cm
AT Performance high mount steampipe manifold
45mm turbosmart hypergate
1000cc injectors
Z32 AFM
Nistune + flexboard
Ebay FFP (plamzaman style)
3" turbo back exhaust
19.5psi both runs
E85
270kw/360hp
412nm/300lb.ft
BP98
241kw/323hp
365nm/270lb.ft
tuned at Garage 7
Edited by CRSKmD
  • Like 1
  • 2 months later...
  • 6 months later...
  • 7 months later...
91 R32 GTS-4 Dyno in RWD only - 297WHP
Automatic transmission(4th gear pull)
Internally stock motor, Nistune ECU
Rb25 High Flowed Hypergear Turbo 15psi
Apexi down pipe, test Pipe, Blitz Jasma Exhaust
Blitz Return Flow FMIC, Z32 MAF
Deatshwerks 550cc drop ins, Nismo FPR, Walbro 255 pump (stock wiring)
Splitfire coil Packs, NGK R's
Engine can make more power, Had trouble keeping the auto trans in gear, was not happy with the power it was making.  Time for M/T swap.
Edited by GreyZ33Track
Added to parts list
  • 2 months later...
C33 Laurel
r32 rb20det
stock unopened motor
stock injectors
stock turbo stock coilpacks
stock ecu
same side front mount intercooler
2.5" exhaust
Aeromotive fuel pressure regulator
Aeromotive 340lph fuel pump
turbosmart external wastegate
15psi boost
  • 4 weeks later...
1989 R32 Coupe (track sled)
RB20DET - Unopened
Haltech Platinum Pro Plug-in
TD06-20G / 8cm housing
TOG Manifold
Turbosmart 45mm hypergate (ext), 14 pound springs
Turbosmart FPR
Bosch 044
GReddy copy FFP
Ford Mustang ebay injectors
Splitfire Coils
Hybrid Intercooler
Stainless 3" Dump to HKS Super Dragger 3.5" system with both mufflers, de-cat
280rwkw, 400Nm on PULP 98,
Tuned by Trent @ Chequered Tuning
Edited by avonbarksdale
Typo
1992 R32 coupe
Rb20det - unopened
Nistune ECU
Stock intake manifold
Tomei FPR
440cc injectors
Z32 afm
255lph walboro fuel pump
Ebay splitted dump
Blitz front pipe
Stock cat
3" stainless catback with both mufflers
Splitfire coil packs
Greddy ProfecB II
300x600x76mm intercooler
No brand turbo that came with the motor TD05?
98RON
210kw @22psi but it surges
549Nm
  • 3 months later...
Stock RB20DET
LQ9 Coils
Plazaman Front Facing Intake Manifold
HKS GT2510 Turbo
AEM EMS Series 2
Deutschworks 550 injectors
American 92 Octane Fuel
3" Exhaust
227 HP, 169 ft/lbs @ 13 PSI
SAE Corrected on Dynojet 424xLC2
Edited by Tucker S
  • 2 months later...
Initial safe tune on a RB20DET with the Hypergear ATR43SS 1.5 turbo ball bearing chra. This is at 14 psi going to go for more boost soon.
Cam gears
3 inch turbo back catless exhaust
blitz frontmount
custom intake
tomei cam gears
660cc injectors
nismo fuel pump
link G4 ecu
clutch upgrade
This seems really late power to me especially at only 14 psi. Should I be getting more power sooner or is this fine? If this is what I have to live with I wish I got a turbo that made power earlier lol.
I bought some shit aftermarket fan clutch that has my fan going 24/7 so that may be robbing power.,
Edited by Kanaric
Check for intake side leaks, make sure actuator is correctly shut and preloaded, Set cam gears to 0 degrees. This is result form my test car, unfortunately it had a broken piston in cyc 6 and could not stop miss firing up top. It made 215rwkws, 20psi by 4000RPM.
Stock Rb20det R32GTS4
600cc injectors
Walbro 470L fuel pump
Hypergears ATR43SS1 CBB turbocharger internally gated bolton
Aero flow front mount intercooler
3 inches turbo back exhaust
Nistune ecu + Z32 AFM
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
