Hi guys,
I recently finished my forged 25/30 all built and wired up the my garage by myself.
Parts consist of:
Mahle 86.5 pistons @ 8.5:1 cr
spool rods
arp gear throughout
nitto oil pump. using one 1.5mm restrictor, with the other blocked.
vct internal feed
ross race balancer
complete bottom end balanced
rebuilt head with std cams and valves
Performance valve springs
1.0 mm cometic headgasket
ebay inlet manifold 90mm tb
aeroflow fuel rail
1400cc injectors
ls2 coil plugs mounted as coil on plug
hybrid exhaust manifold
kinugawa t67 with t04 compressor
turbosmart 45mm gate
turbosmart boost solenoid
3in straight through exhaust
walbro 460
haltech ps2000 with racepak dash
currently on its run in tune, 288kw @ 17psi and only reving to 6k rpm on bp98
Edited by Pridenjoy
Forgot to post the final tune. After all the waiting, the end result is a little disappointing, expected a bit more grunt, but not over yet, a few things to sort out .
Going to beef up the fuel and exhaust.
Flex tune and see how it goes.
  • 1 month later...
RB25/30 NEO
Spool rods
wiseco pistons
Balanced
Arp everything
N1 pump with billet gears and oil relief setup. and longer crank drive collar
ASR 8.5L sump
Standard head with 270-9.2mm cams no vct
performance valve springs
6x LS2 coils
cpc plenum
steampipe manifold
GT35 .82 rear internal gate
660CC injectors
420hp @22psi injectors at 85% duty cycle
Also couldn't get it to hold more boost up top (could of wound the pre-load up but decided against it)
BP98 fuel
Auto
  • 3 weeks later...
RB 26/30
BW S362 / 88-75
Fullrace twin scroll manifold
270deg cams
etc....
Dialled cams for low down at the cost of some top end. Boost is only 17psi while I get used to it, so there's a lot left in reserve.
0E5CABF9-BB4D-4833-86D0-457E5070507E_zps
  • Like 1
  • 3 weeks later...
RB30 bottom end, RB26 head
Forged rods / 86mm Wiseco RB26 pistons, CR about 8.7:1
HKS Step 1 cams 8.7 lift, 256in 264ex, exhaust mildly ported
ID1000
RawBrokerage T4 twinscroll manifold with two Tial F44 WG (1 Bar spring presure)
EFR8374 1.05AR twinscroll
3.5" exhaust
45mm screamer pipes
Made over 600hp on wastegate pressure:
700 with manual bleed valve (unstable boost dropping to 1.45 bar at redline)
95 octane pump fuel (as setup will go to the states next year in a R32)
Video:
Edited by AndyStuttgart
Just had the first run in tune, not sure what I am going to get when it has the final tune, I will post the results. They said it was at 7500RPM ?
Nitto 3.2 Stroker Kit
PT6262 turbo
Custom 260 10.8 cams,springs and retainers
Haltech 34GTR ECU/Boost controller
3.5 inch custom exhaust ( as a DD as quiet as it could be without restricting flow)
Supertech 1 mm OS Valves set
RB 26 head, cleaned up
9Lt sump conversion/ Nitto comp Pump
Koyorad Radiator
Walbro 460Lt fuel pump, (see how it goes)
Haltech E-Flex Sensor kit
Other stuff needed to make it all work
Yokohama AD08R
Nismo Super Coppermix twin C Spec clutch / Slave Cylinder
Quaife Front diff
Modified Trannie
Nismo 2-way LSD back diff
Just leaving the final Dyno to finish my tuning experience :)
98 pump@ 22psi = 437kw
E85 @ 22 psi = 462kw
E85 @ 25.5 = 475kw
Other Dyno is overlay of old tune 98 pump 367kw @ 22psi and new tune on 98 pump 437kw @ 22psi
  • Like 1
-Freddy copy plenum
-id1000cc injectors on big rail
-Sard fuel pressure reg
-Spitfire coil packs
-China replacement turbo
-Adaptonic computer
-Rolling automotive front mount
-80mm throttle body
Made 305.5rwhp (227.4kw) on 15psi
Tubos shit. Will make more with a quality turbo.
E85 2000 cc inj
Twin bosch 044s and surge tank
Haltech platinum plug in
Gtx 35 1.06
Ported kelford cnc head
Kelford heavy valve springs etc
Tomei head gasket
Arp head studs
Kelford 272 274 10.85 lift cams
Rips stock bottem end with prep upgrade
Tomei oil pump
Rips 10l L sump and gredy oil cooler
426 kw at all 4
26 psi
Edited by danny14
RB 25/30 Neo running E85
435 rwkw @ 23 psi
Nitto I beams
Custom CP pistons 8.8:1
Garrett GTX 3582 1.01 exh
Tomei 260 type B poncam
Mild port/polish head
Tomei dual spring and retainers
1500cc ID injectors
Walbro 460 intank twin 044 from surge tank
3" straight thru stainless exgaust
Custom stainless header
NPC twin plate
Retained VCT
  • 3 weeks later...
Gtx3076
Tial 44mm ext gate off housing
Lt12 ecu
Eboost street
850cc injectors
Hks 256 in 264 exh vct cams
Hybrid manifold
Forward facing plenum
Precision cooler
All through a built r34 auto with 3000 rpm converter
15psi boost
E85 and lt16c computer next month
E85 lt16c Ecu 6boost manifold upgrades.
  • Like 1
  • 2 months later...
Hi guys,
Parts consist of:
spool rods
arp gear throughout
vct internal feed
ross race balancer
aeroflow fuel rail
1400cc injectors
walbro 460
UPDATE...
After the engine was ran in I strapped it down again which it made 320kw on 20 psi, and having iat problems.
I then fit a new plazmaman intercooler and ran it on the dyno with pump e85 making 374kw on 21psi, which is all the little t67 will do.
Edited by Pridenjoy
  • 3 weeks later...
Ok about time I posted in here..
Racepace Built RB26/30
Mahle 87mm forged pistons
Argo Rods
HKS 256 8.5mm lift cams
adj cam gears
Sard 700 cc injectors
Tomei Oil pump
Tomei Headgasket
Std Coilpacks
Std Valves and head
Power FC
3.5" Racepace custom exhaust
Walbro 255 pump
Garret 2860r-5 Turbo's
HPI dump pipes
Std manifolds inlet and exhaust
R33 GT-R intercooler
Std R33 GT-R Airbox
Balanced Blah blah
375rwkw @ 17 psi BP 98 (369 for the track)
  • Like 1
  • 2 months later...
Very similar build spec and result to acsplit above.
My goals are for a responsive track car I can daily on 98 - drive and fill up anywhere.
RB30 Bottom end w/ Ross Racing Pistons & Spool forged rods
Garrett 2860 -5 Twin Turbos
Tomei Expreme Dumps
Low comp 7.85:1 (to keep things safe on 98, YES I'm staying 98 for a while)
ARP M11 Head Studs
Nismo 0.9mm Metal Head Gasket
+1mm Supertech valves with Supertech springs & retainers
Tomei Pro Cams 260 10.25mm lift
ID 1000 injectors
Autronic SMC / 500R CDI (Super Old School!) firing through Splitfire coils
Adj cam gears
Nitto Oil Pump
Single 044 pump & 2L surge tank
12791116_1183587054999874_67586165268249
  • Like 1
  • 3 weeks later...
Had the car on the dyno today.
Still early stages at the moment. Just finished running-in new the RB25/30DET. Timing and fuel is conservative, purely as we ran out of time in the day to make improvements.
A quick power run on 22psi (E85) resulted in the following:
411kW at wheels on just shy of 20psi
428.8kW at 22psi
Aiming to run up to 30psi
E85 @ 25.5 = 475kw
Update
Decided to go V-Cam :)
Lost a little up top, but it the injectors and Turbo were just about maxed, all good
The end, I hope :/
  • Like 1
390.3kW at wheels at 18psi
411.1kW at 20psi
428.8kW at 22psi
Aiming to run 30psi
Video of the 22psi run:
https://m.youtube.com/watch?v=VhnlYVwQlBg&feature=youtu.be
  • Like 2
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
