Good read.
One thing I would like to chuck into the ring is the performance side of things.
I remember when I switched to iridiums in my CBR900. Holy shit. SOP dyno said 5hp right thru the rev range. And it wasn't just the switch from old to new plugs as I had done that 10 times before going iridiums. And throttle response was markedly improved. It help with the throttle hand/rear tyre connection something fierce.
I've been an advocate of iridiums ever since.
Why am I surprised that people don't report better performance with iridiums over copper in their cars?
I picked up some iridiums this week. Will chuck em in with fresh oil next weekend and report back.
  • 3 weeks later...
ok ok very confused after reading all that!
i have brought new coil packs, and i want to change the plugs at the same time and the coils!
my car is r32 with rb25det s2 simple mods fmic, fuel pump, full 3inch exhaust and a hi low boost control 7 and 10psi
i drive mainly on 7psi!
what plugs and what gap?
thanks
thanks
The rule of thump, with those mods you run bcpres6 copper ones and if you boost past 13-14 go 1 colder and get bcpres7
no need for confusion really...
90% of people on here and pretty much every tuner i have spoken to use and reccomned either BCPR7ES gapped @ 0.8 or BCPR6ES gapped @ 0.8
use that and you will be fine
its not that iridiums aren't better also.... its just that in a modified environment they can die just as quickly as coppers and offer no real gains other than the price
Fixed my missfire that i had for 5 months by putting in BCPR6ES at .7 gap, had iridiums in before at at heat range 7 and .7 gap and they were shit, but most likely due to car running really rich for so long.
Put platinum ones in mine about 3 years ago done about 65k still fine checked at each oil change or service
Running light mods and .85 bar boost no problems no miss fire best plugs i've bought so far but a bit expensive
thought id try them after I was surprised they lasted over 160k in my astra 2.2 coupe (holden)
Edited by jjskyline79
I bought a six pack of Bosch Platinums today from Super Cheap. Cost me about $38. They are the FR7DPX ones. Has anyone used these before? They are pre-gapped at 1.1, but keep reading on here folks going for a 0.8 gap. Have read things in this huge thread and will continue to do so. But so far seeing way more references to NGK coppers vs anything Bosch.
yeah, everyone seems to love the nkg's. but when it comes to gapping, if you're pretty stock then 1.1's will prob be ok. it's like oil tho, different for every car, and might take a few changes to get the perfect setup. just listen out for a miss
found my cause of misfire, 2 of my coils were missing the spring, and as a result there was some white powder stuff on top of the plug and in the coil at the base.. cleaned out and with new springs and plugs fixed my missfire.
  • 5 weeks later...
was taping up my coilpacks to try to solve a missfire while i save for yellow jackets and had a look at the spark plugs, only to find them very very black. I'm using ngk bkr6es plugs with standard 1.1mm gap and they have about 3500km's on them. do i need a higher heat rating? or is it running rich or something?
car is a stockish r34 gtt with 3.5" catback somehow boosting to 12-13psi (still trying to figure out why that is)
Edited by Galois
If you have dodgy coils try gapping your plugs down to 0.8 til you get new ones. Could possibly explain why they are so black (don't all RBs run rich from stock?) or if you're keen try some NGKBCPR5ES
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
