I saw a preview on A Current Affair that will air on wednesday 15th feb about how everyone should contest speeding fines. The police have apparently not been looking after their gear and everyone can now get off... bla bla bla. I am sure it will be spectacularised and not the entire truth but may be worth watching.
https://www.sau.com.au/forums/topic/105857-a-current-affair-tonight-15th-630pm/
hahahaha you me and everyone else with an import!!!
TMU  <_<
i been good for the last 9 months.. only cause i havent driven it thanks to engine conversion >:P
hope to be driving it again in a couple weeks :S that one point isnt gunna last i can see it now.. i better pull out the push bike and start using it to get some practice
Edited by Wazz
i think its a repeat story of something they had a while ago about a certain type of radar gun being faulty or not properly calibrated
in NSW if i remember correctly....
Yeh I remember that one last year
i only got one point left aswell :P
Apparently there is a new angle. This from our radar expert on the Roadsense discussion group.
"There will be a segment on Section 10 of The National Measurement Act 1960 re Traffic cases on a Current affair channel 9 Wednesday nite.
It is a very important subject which the system has been avoiding."
TMU  <_<
Not EVERYONE! My last contribution to the state's coffers was back in 2003, and I don't remember the one before that, so I probably have them all available.
But I'll still be watching.
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
