  • 2 months later...
How much oil pressure is to much?
My RB28 has Tomei pump, 1.5mm head restrictor, 0.8mm turbo banjo bolts, 0,045mm main bearing clearance and 0,050mm conrod bearing clearence.
Tomei oil pump is at factory setting (max pressure) at the moment.
My Greddy digital gauge showing up to 7.5 bar on hot engine at 5500rpm with the 15w40 running in oil.
Will go back to 10w50 soon.
Seems fine at cold idle (6 bar) and hot idle (3 bar) and normal driving with hot engine at 3500rpm (6bar)
Should I go down with the pressure?
^^2nded.
I've got a tomei pump and have just put on an accurate oil pressure gauge.  runs around 100psi at 5000rpm hot. 15w50 oil, oil cooler sits at 82 degrees unless on the track.
considering dropping to 10w40 or removing a shim from the tomei.
  • 1 month later...
So considering the welsh plug fitting is just for breathing and not for a drain there should be nothing wrong with having the fitting point directly up after leaving the back of the head correct? Only putting it like that to make more room for a coolant bypass plug on the rear of the head too
Don't bother.
  • 1 month later...
Hello
I have now run my RB26 for two seasons. About 14.000km in total. I re did the hone and new piston rings this spring and buildt a new catch can. But it is coming some oil out from the filters on top of the can. I also had aboud 3dl of oil in it after 2500km drive on the Autobahn including 2 laps at the Nürburgring.
I have the rear head drain to under oil level. As I now understand this is wrong?
My setup is:
-Sock balanced bottom end.
-Jun oil pumo with spline drive gear
-Drilled oil return galleries to match head gasket
-Jun oilpan baffles
-Mines head baffles
-1.2mm restrictor
-AN10 from rear turbo drain to top of catch can
-AN10 from right side of oilpan above level to top of catch can
-AN10 rear head drain to under oil level in oilpan
-AN12 from rockercovers to top of catch can
What I'm thinking is to move the head drain to the position on the right side of oil pan above oil level. And only have the rear turbo drain as crank case to catch can ventilation. Is that a solution?
11 hours ago, SSM said:
Hello
My setup is:
-Jun oilpan baffles
-Mines head baffles
-1.2mm restrictor
You want to get the blowby in the sump out of the engine without it having to go through the oil gallery.  So if you can connect a line to the pan above the oil level then you can hook the other end into your catch can.  Which is the age old fix for engines with oil carry over in the blowby.
Already got one on each side ?
On 10/12/2017 at 5:16 AM, SSM said:
Hello
Yes
My setup is:
-Jun oilpan baffles
-Mines head baffles
-1.2mm restrictor
1.0mm would have been better
Useless... remove
OK
Useless... possibly worse... remove
OK
Ideally you need a second breather from oil pan above oil level to bottom of catch can to allow oil to drain back when not under pressure.
Your catch can needs to be minimum 2 Litres
NO
do not dump the shit from your catch can back to the sump, theres a reason it its called a puke tank (drag racing terms) most importantly, if you run e85 or any kind of alcohol fuel, it literally breaks down oils, the shit that ends up in your tank its not pretty. sure vent the sump, but from the intake side, to the TOP of your catch can. dont drain it back to the tank.
my engine (25/30) loved high oil pressure, 8L sump, baffled, 7500rpm, 2.5L accusump, 1.2mm restrictors, vct blocked, drilled out oil drains in block and head, -12 rear head drain (to ex side)  2X -12 sump vents to catch can (intake side), baffled cam covers with 2X-12 to baffled catch can, all vented to atmosphere. use to spit hardly any thing, even after a full w.e or thrashing at power cruise or racewars etc.
7 hours ago, SSM said:
Thanks
So use the rear turbo return as a crankcase vent is no good?
I'm a bit concerned to have a return from the catch can to the oilpan.
Exactly what is the difference between the oil in the cam covers and the catch can? Does it magically change it's properties when it travels through the line between the cam covers and the catch can?
no man, it "magically" changes properties when it leaks past the rings into the combustion chamber where the enthanol/alcohol is forced into also.  ill find the pics and show you the shit that comes from a catch tank when ethanol as effected it.
Quote
Okay so here, this is my can and cam cover lines after a full weekend of racewars, 400m 800m and 1000m of flat out high rpm, car took a hammering all w.e, i drained under 50ml out of my tank. which showed, a very minor amount of water (from condensation) sitting on top of oil which you can see below has been effected by ethanol. you can even SMELL the ethanol in the catch tank. (i also drained my sump to find 8L of perfect quality oil which i put back in the car).
that oil is the penrite 10 tenths racing oil which is compatible for alcohol and ethanol fuel, but you can clearly see the oil has been badly effected by the ethanol.
i dont know, what do i care if you decide its a good idea to drain you shit back to your sump, doesnt effect me, but why? what is the point in draining a couple ml or a couple hundred ml??? at most if its really bad?? back to your sump? whats the point? what do you get out of that? nothing. so why even risk it?
FB_IMG_1508291265981.thumb.jpg.52a34366f43549b69880814951a29bca.jpgFB_IMG_1508291273480.thumb.jpg.d2bd1b7d98a332915710cfe27fccad70.jpg
Edited by ScreamerNewbie
Once again, how is that different to the oil/mist in the cam covers that drains back to the sump?
The question is, is that ethanol affecting the oil or water condensation? and is that straight after driving the car or because you left warm oil sit in the catch can?
Also nice and dandy for straight line stuff, that's never been the issue... Trying hammering around a Racetrack and you will see why it's better to have oil from the catch can drain back into the sump rather than no oil in the sump.
I'm also going to take a bet that my car not only survives Racewars and Powercruise weekends (and years and years of them) but also is more than happy to lap tracks running 2 bar with no issues
  • Like 1
    • Splitfire Nissan RB Twin Cam Street Series Splitfire Coils. Basically brand new less than 10kms use. Only selling as ive upgraded to the IGN-35A coils $400 price pretty firm
    • We have 2x Swifts and my plans for a Swift, unfortunately, do not extend to an intake and an exhaust. I've been having dirty thoughts about a 2.5L Suzi V6, AWD gearbag out of a suitable donor, rear floorpan graft to take the rear cradle from same, and either trumpets of evil or a small supercharger. If I'm going to make noise in a Swift, I want it to be anti-social, evil handling and rough. Probably need to be fully stripped inside, matt black paint, plastic windows, 7" wide wheels, big brakes, silly suspension, etc etc etc. I have no idea if any of the proposed driveline components could take the pain. But it would be a hoot finding out.
    • Really, anyone modifying a car isn't being financially smart. We're doing it for the things we love. And honestly, a high revving, light, NA car is actually pretty darn fun. I used to have a Swift Sport, and I miss that thing as a daily, and yes, doing something like some intake and exhaust stuff would have made minimal gains, but would have bought an even bigger smile
    • We are taking pricing back to 2022! The skid pan is nearly double the size of avalon so much better for longer battle runs as seen here > https://www.youtube.com/watch?v=ANxdRf3Do2s When: Saturday 14th June 2025 Where: Winton Skid Pan (Winton Motor Raceway) Price: $145 for SAU VIC Members            $199 for non Members Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. email [email protected] To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and it is reccommended a 1KG mounted fire extinguisher (But not Mandatory). Further details within Supp Regs on the enty link. You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Accommodation:  In an effort to try new things and support other country towns we thought a new location for accommodation was worth trying and Euroa was great last time plus its 30 minutes closer to Melbourne. Saturday night we will book a spot at the pub for a couple of quiet drinks.......   Book your accommodation ASAP before it sells out, there are also other options in town if you want to stay elsewhere and join us for dinner Saturday night.   https://euroacaravanpark.com.au/ Address: 73-103 Kirkland Ave, Euroa VIC 3666 Phone: (03) 5795 2160 Entry link with Full Supp Regs to read: https://www.sauvic.com.au/entry/deca/20250614 Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1. Josh M 2. Anna 3. Luke  4. Katie 5. Martin 6. Tony 7. Alix 8.  9.  10.  11.  12.  13.  14.  15. 16.  17.  18. 19. 20. 21. 22. 23. 24. 25. 26. Reserve List 1. 2.
