  • 1 month later...
Has anyone seen or used mines cam cover baffles with no foam ?
i Have mines cam cover baffles but without foam (was like that since previous owner built the engine) and also my friends uncle imported a 34 Gtr from japan built by JUN many years ago and he said his was the same
pros and cons of this ? Should I be adding the foam in there ?
Also im not sure if the stock metal gauze/mesh is in there either
Well, obviously, if you have nothing in there to keep the mist in the engine the mist is going to flow to your catch can setup and you will have to deal with an increased amount of oil - whatever that "dealing with" entails.
They should have foam in them and if they don't they will still "work", for a given smaller value of the term "work".
  • Thanks 1
  • 11 months later...
Well.... Dyno just finished on my forged rb25det build. Fitted a blanking plug on the centre hole and left the other 2.
It now has noisy lifters above 5K rpm and gets worse as it revs. Oil pressure is spot on. My tuner said to never use restrictors in a hydraulic lifter head as he has seen this before...
Lesson learnt, never take advice from this page without discussing with professionals.... FFS....
I can't see that as a recommended option in "the table"
How does he explain why so many other people (including me) have fitted restrictors / blocked oil feeds, and haven't had noise problems?
Did exactly what it says on the table. Have you always been a flamin mongrel or do you still have bits of your mum stuck to you from birth?
Which part of the table did you follow? I can't see any of the options that say to leave the rear feed as is.
You'll make lots of friends here dude - good luck with your engine..... FYI my mother died a few months ago - so lets hope we meet up one day and I'll rip whatever is left of your mother off you, you fcking arsehole.
Edited by GeeDog
  • Like 1
  • Haha 3
That table would probably be better with 1.25 restrictors instead of blocked off for the standard pump cases.  That would include the N1 pump, because it's really not that much larger (if at all) than a stocker.  Neos have the N1 pump, for example.
I used to sell restrictors and often for hydraulic lifters including my own RB30 with an N1 pump and external fed VVT ...think it was 2 x 1mm from memory but was years ago and my memory is fading.  Joe Kyle built the RB30.
Hey guys, I'm getting oil come out of my catch can.
Its a 2.6, which was just recently built, after spinning a bearing at the track with an inferior oil control setup (small hi octane catch can and overfilled sump lol).
- 9l sump baffled, with trap doors
- 1mm restrictor
- Hi octane cam cover baffles
- 5l baffled catch can setup  (2x breathers from the head, sump drain, sump vent and a big filter vented to atmo)
- Nitto head drain
- Nitto oil pump
- Nitto crank collar, with crack tested crank
- Custom oil cooler setup
Now the issue is, I'm getting oil coming out of the filter on the catch can. This even happens on regular drives with a pull here and there. I cant quite work out why, as the catch can is a decent size, is heavily baffled and it even has a drain.
I don't like the fact oil is spilling out. Is there an issue with the breathing of the engine, or is it just a problem with where the filter is located?
Edited by Darmanin10
  • Like 1
To help you diagnose - try putting a vacuum/pressure sensor on the sump and logging it.
You might find it is being pressurized - hence oil can't get back to the sump from catch can or rocker covers and fills the can.
Also (what I can't quite see) you have two breathers to the catch can, and only one to atmo?  Consider making this larger otherwise the velocity of air out can be high and drag oil mist with it.
I was going to say the same things as R32 TT just did.  Pressure gauge hooked up to the breather vents, see what sort of pressure is in the system.  (OK, not same, similar.  He says measure at sump, and if the situation is bad the pressure down there will be higher than at top of engine).
As to the catch can, a single small vent to atmosphere may be restrictive relative to the volume of flow coming out of the engine and lead to pressurisation, high velocity through it and easy oil mist carry over.  The solution might be a 2nd catch can in series to try to give somewhere for the oil mist carryover to drop.  If that worked, I would plumb the exit back into turbo inlet to not breathe to atmosphere at all and the suction from the turbo would also help to reduce the back pressure.
It looks like it should.  It's certainly more than double the XS area of the 2 main inlets, so it should be less restrictive than the pipework leading to it.
Doesn't mean that the whole package isn't just being pushed too hard by excessively large amounts of blowby.  Probably should check that, as described above.
One other thing to check.    Are you absolutely sure that you haven't slightly overfilled the sump?
If it is just a little too full, more than you need then suddenly you have the crank churning up oil and frothing it up.. that will sit up in the rocker covers and be pushed out - the aeration makes more volume, which is turn makes it worse and gets churned up by the crank more.
Try taking a litre out and go for a drive.  (watch you oil pressure obviously, but a litre shouldn't hurt)
That catch can exit looks like plenty I would have thought.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
