Hey all.
Picking up a 4 point harness on Wednesday, but I'm just wondering, how do I go about mounting it all up? I'll be keeping my back seat IN, and be mounting the main part on the back on the parcel shelf. But how do I mount the rest of it?
Thanks
Car is an R33 GTS-t Series 1
  • 4 weeks later...
  • Replies 75
Posted Images
Yeah too much angle.
In the track GTSt I took the rear shelf out to use FIA plates under the shelf with eyebolts on top, but in the GTR I use eyebolts straight into the stock seatbelt mounting points.
  • 5 weeks later...
Can anyone confirm that mounting shoulder straps on rear seatbelt mounts is acceptable and would pass scrutineering at a CAMS/AASA event?
I understand you have to be within a certain angle, has anyone had any major issues and had to screw around and strengthen/mount on parcel shelf....
  • 3 weeks later...
hi, if anyone needs one of those "L" shaped brackets to mount the inner, lower strap of the 4 point harness to the trans tunnel without having to drill a whole I may have a couple spare. I bought a few in japan as they are hard to find here, and farken handy for mounting a harness in your skyline. just pm me and I'll sort you out.
Mounting the harness from the lower rear seatbelt mounts is ok.
It is within the angles specified in the CAMS manual.
Its stong as! it passes crash tests from the nissan factory and is within the angles set by CAMS. In my S14a I use the rear lower seatbelt mounting points.
I looked into mounting my harness from the parcel shelf using a 5mm backing plate. There was room to do it, but the parcel shelf itself is made of the thinnest bit of sheet metal I have ever seen. I reckon you'd rip it to shreds and pull the backing plate right through it if you had an accident.
Edited by nismoman
  • 1 month later...
shoulder belts are done the same way as you described. purely as those two anchorages are load tested and re-inforced since they were desinged to take the standard seat belt anchorages. lap belt i remove one bolt holder the little rail thingy and replace with eye bolt. the inner mount is a bit tricker and the only sure solution is to drill a hole and weld a plate on the other side, but it's not very nice to your car, or very neat.
so the inside one you are screwing into the seat? that should be ok but with a race seat of course that's not an option. the harness needs to be fixed to the car body at all 4 points. hence the need for the bracket on the inside mount as there isn't a bolt there (it's a stud).
I am going from memory here, so I may be compeltely wrong. (As opposed to not going by memory & being completely wrong anyway, which happens to me a lot these days)
Anyway if you look at the bottom left hand corner of page BF70 of the R32 Gt_R manual. It replaces the anchor bolt on the seat buckle which goes into the seat rail according to the drawing.
You probably have a point about the location, but they never seem to have a problem with the lap sash done that way...
Not a great idea fastening it to the seat. In the event of an accident the seat is the most likely point of failure. Hust like in race cars they dont mount harnesses to the chassis, but instead they mount the seat to the cage and the harness to the cage. Car can distort but the cage is designed to protect the passenger cell
Well fair point. I was working on the idea that I would fit a harness & seat to my new car. Unfortunately it looks like I will have to do some more work as I want to keep the lap/sash arrangement as well as a harness. The buckle being attached to the seat frame complicates things if you want to replace the frame with a fixed side mount system.
Edited by djr81
yeah i dont use the lap sash bet with my cobra race seat. for 2 reasons. 1, they are not designed to work together. if I was wearing the standard belt and had a head on impact i would submarine my way under it. and 2, there is no where to fit the inner buckle/clasp.
for me: regular seat i use regular belt
race seat i use 3 inch 4 point harness. :happy:
Well they are the other two problems.
Because my thing isn't as race orientated as yours & becasue I have to travel a bit to get to the circuits I wanted to retain the normal belts. I have seen this done with fixed back seats but you have to be a bit careful in the selection. Not sure how to get around the side mount/seat buckle problem, however.
Submarining is why I don't want to use a 4 point harness. I find they ride up on my guts too easily (maybe my guts wobble too much over the bumps or something) hence I wanted to use a proper 6 point harness. Hell if you are going to be strapped in you may as well be STRAPPPED IN.
yeah, the only reason i haven't gone 6 point is i didn't want to drill a hole in the floor. the way my side strips go with the fixed seat submarining shouldn't be a problem. with a stock seat though it definately would be (no harness guides to keep the belt down low).
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
