wgmg - the idiot on Reid Hwy the other day in his 94 Excel with 16' chromies, sitting approx 30cm away from my rear bumper while i was doing 90. I suspect he was trying to impress his gf. What a pig
you can get them in japan already but not here , like all cool things really
theres a couple of domestic robots on the market , sony have 2 models , honda have a realy expensive one avaliable for lease
gear grinder :
people who claim they can get a brand new r33 rb25 power fc with hand controller for 814$ delivered from japan but wont say where from.....
yeah right
what grinds my gears...
driving a stupid lancer while wanting to get a skyline, planning to sell my stupid lancer so i can afford a skyline, then getting my car scratched in the car park (my fault) so having to sort out insurance and the prick whos car i scratched too - sh!**y "top of the range" magna (pfff top of the range my a$$) and then him saying he wants me to pay for a hire car whilst his gets fixed, and that it has to be a big car because he cant fit in little cars. then knowing i have to pay get my wisdom teeth out in three weeks and not having private health care, or be on the healthcare centerlink thingo =[ lame
p.s new here - scouting cars for sale =]
welcome lucinda
ive been 'looking' for nearly 2 years :)
wgmg is i want to do some things to my car (like better brakes, bigger swaybar so my car doesn't understeer everywhere) but my shit uni timetable doesnt allow me to work convenient times
oh well :)
fuggin' bad hair days.
Why is it, that when things go pearshaped it has to happen it a long string of clusterf*cks?
Work car poops itself on the way home, get a power cut so can't finish the carby rebuild, sleep in the next morning, have to drive the Stagea to work at a refinery *cringes*
Pull up in the car park and get out just in time to watch a bird cr@p on my driverside door and windscreen.....:D
TFIF.
i'll tell you the problem, you got it set on evil.
my name is krusty and i'm going to kiiill you.
hehehe. i didnt even pull the string.
What's grinding my gears? The stupid finance department not telling us what the hell is going on with changes in the accouting system... cool. we might as well sit here and play cards then.
wgmg is fellow Sauwa'ers'ys thinking they spot you on Reid Hwy doing 130 when you're actually sleeping that afternoon, and then make me paranoid & stop me from drinking my beer.
AARRRGGGHHHH
AARRRGGGHHHH
you are freaking out mannnnn
license please
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
