Are you sure?
That baby blue car is from the UK last I checked. gtr converted gtst
Really? Are you sure? When the car was in Malaysia it was a gtst that had an RB26 transplant and GT-R look conversion. It even had gotten the wider fenders done here...
This is what it looked like before the paint job.
And after that it went all looney and shit...
Edited by DarkChild
but why ? Why transplant an RB26 and then dress a GTS-T to be a GTR?
= defeats purpose (of transplant). or buy a GTR in first place
I still like the colour, but less impressed overall :/
It's difficult to find a R32 here let alone a R32 GTR. He loves going sideways most of the time anyway. RB20 was swapped out for a RB26. Rear quarters were D-Max wide body kit. Each to their own I guess...
You can check out the car before it went 'looney' here.
Edited by DarkChild
  • Like 1
look in the R34 picture thread. it looks like 1 in 10 cars is a 34R over there
Lot's of R34's here but many are not even GTR's. Just made to look like it... R33's and R32's not as many. Plenty of R35's too lately.
  • Like 1
No idea mate. Haven't a clue... When I find the time to ask all of these people, I'll get back to you....
Haha!
As long as you keep updating your blog, all is good :D
That looks awesome!!!
Thanks man!
Took the pic myself :)
Taken during a cruise where I pretty much didn't get a 1km from mine and started leaking coolant from a minor split in a hose.
Did the rest of the day as it was minor. A mate in another R32 GTR took these and dropped em off today. Hope you like.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
