The 350Z disc cannot be used on the Skyline because of the different hat heights, the 324mm Skyline disc must be used and I understand that the two calipers use different size mounting bolts.
So assuming these are the only differences (to the best of my knowledge) then fitting 350Z calipers would not be an insurmountable task (in conjunction with the GTR33/34 disc) but unless you could pick up the 350 calipers at a bargain price I would suggest using the GTR calipers and saving yourself the hassle
the 350z/ v35 skyline ones use a m14 bolt to mount them where as 33/34 gtr uses a m12.
and ther offset of the skyline ones is off by about 3-4mm.
i tried fitting 33/34 brembos on a v35 and the bolts went big enough and the caliper rubbed on the outer face of the disc :
hope that helps.
ps... you can bolt them up but youd need the matching discs with the calipers.
Thanks guys, thats helpful. I'm interested because a company in the US called RacingBrake has released a 6 pot caliper/adapter/disc/pad set for the 350Z/G35 that's about AUD 2500.
http://www.racingbrake.com/350Z_G35_03_05_...026-311-611.htm
Being the US they don't have access to GTRs like we do so I thought I'd see if anyone knew if they were compatible.
Regards
Edited by Scooby
I think this all got answered, but like t04 said the only difference is the thread on the bolts. Just match calipers to discs and it should be fine. I just never got around to getting bolts the right length
  • 4 years later...
Bit of an old thread bump.
Just want to confirm what I am reading.
If you got a complete front aftermarket brake kit with calipers, rotors and brackets made for the G35/350Z, it would bolt onto a R32/R33 Skyline if you had the brackets have M14 holes on one end for the caliper and M12 holes on the other end to bolt onto the hub correct?
  • 1 year later...
hmmm, interesting.
looking for the same answers for the same reasons...
so, to sumerise, get a complete kit, and it should fit..
is that it?
might have to take the plunge, and try for myself.
if i do, will put up a write up.
Im running r34 brembos on the front of my Stagea which is the same as a v35/350z in the brake department. The offset may be different but other than that they are the same calliper. Just make sure you get the disks from the model the callipers are from.
I have a spare front seal kit for these these brembos if anyone needs one.
How similar are the Brembo brakes that came on 350Z's and R33 / R34's?
In the front they both run DB1520 pads and the rears run DB1521 - so if the pads are the same they they must be very similar.
The difference seems to be in the disk offset as shown in the attached link http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=41147
So the big question is:
Are the seal kits interchangeable as you can buy factory kits for 350Z's from the US for a very good price?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
