Guys,
An update on the prices for RE55 R compound tyres from Donnellans. Prices have gone up a bit from the prices listed in the old thread Here.
There's a couple of new sizes available too. Available from Donnellans in Box Hill... Oakleigh shop will match the price if it's closer to you.
New prices:
[ 18" ]
Bridgestone RE55 225/40/18 . . . . . . . $376 per tyre $395
Bridgestone RE55 245/40/18 . . . . . . . $383 per tyre $405
Bridgestone RE55 265/35/18 . . . . . . . $418 per tyre $440
Bridgestone RE55 285/30/18 . . . . . . . New Size $478
[ 17" ]
Bridgestone RE55 235/45/17 . . . . . . . $348 per tyre $355
Bridgestone RE55 235/40/17 . . . . . . . $351 per tyre $366
Bridgestone RE55 245/40/17 . . . . . . . New Size $386
Bridgestone RE55 255/40/17 . . . . . . . $375 per tyre $393
[ 16" ]
Bridgestone RE55 225/50/16 . . . . . . . New Size $290
Comparison of tread pattern between older Bridgestone 540s and current Bridgestone RE55:
Enjoy :wub:
Cheers.
  • Replies 62
I bought a new set only a month ago for 410 each at Box Hill.
Price went up early June. I called end of May and they were $412 fitted, then called late June $440 fitted.
Something to do with the price of oil was what I was told. Great excuse for retailers if you ask me.
I know some people run these on the street, but does the sidewall make it really stiff and rough on general roads?
Ive had some Falken Azenis RT215 semi comps, they were 16's, and it was a rougher ride than the street 18's on the same car. These were back on my Commodore.
Are the sidewalls stiff like the Falken track tyres, soft like road tyres, or inbetween?
I run them on the street & they exhibit the following characteristics:
They tram line like a bitch.
The stiff side walls give you a rough ride.
They make a shit load of noise, especially at 80 to 90km/h
They pick up every bit of shit on the road & fire it up into your wheel arches.
The don't last very long.
RE55's are like the Falkens, the major difference being you get proper grip to offset the cost & the other hassles.
With a proper set up & a clean track - 1.25 laterals gees of fun should be yours to have. :O
Edited by djr81
With a proper set up & a clean track - 1.25 laterals gees of fun should be yours to have. :)
You forgot to say - they go fast!
But yes the above is true. (Sigh) The price we pay to go 5sec quicker per lap.
The cost of rubber these days.
Bouncing higher and higher.... :) the god rubber
So ...My Tyres are going to cost more than the rims i ordered..
And steel has gone up in price too......
I just think it is all hype to make us pay more on the products they sell....like what was said on tv
I run a small business making office chairs and i have had no problems with price rises from my suppliers
We use steel and oil based products
This Sucks....We should all get together and have group buys for this...they are ripping us off
What next...our shoes are going to up in price by !5% because of the price of petrol :)
for those interested these tyres are in fact semi compound rubber, which is suitable for track usage. they are not recommended for normal street use. you can use them on the street but they react completely different to normal street radials. they are roadworthy and acceptable as far as ADR's and vicroads are concerned however.
the expected lifetime is somewhere around 8,000k's to 10,000ks for a set.
that would be normal street use i would expect, not sure how long they would last given full track usage. ie: not sure how many track days they would last
Well I put a set on approx 12 months ago. They have done a number of track days, approx 5000kms and are completely shagged.
If you are keen enough you can destroy a set in one track day.
The other thing that amuses me is how much of a difference some people expect them to make in a one minute lap. You may be lucky to pick up a couple of seconds over a good set of street tyres. Nothing more. Certainly not the 4 or 5 seconds over a minute lap that some people believe.
:thumbsup:
OK then...
Lets source a great tyre on road and track.....Set up a group pricing buy with the company
and then loose control....because it hasn't cost us much
Phillips Island - we tested with four people and they all improved by exactly five seconds straight away.
Sandown was like 4 seconds average
A decent steerer should be able to pull four seconds easy, and come close to five seconds even at a track like Winton.
I dropped 5 seconds off my time at Winton going from streets to semis... 1.43 to 1.38.... I did have a little bit more power, but i also had some brake issues, without the brake issues i think i would of had another second or so in there.... (on that day)
You would only classify the GT-SS as " a little more power". Your car is awesome :D
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
