  • Replies 459
Finally I can say that PS3's are shit. I have played Fight Night round 3 on the xbox 360 and on the PS3 and I can say that the PS3 sux arse, I have played alot of games on the PS3 and finally found a game I could compare between the two consoles and say that overall playability is far better on the xbox 360 and the PS3 takes way tooooo long to load
really... that’s strange. Professional reviewers online seem to say quite the opposite.
Give us one reputable example? Everyone knows that the ps3 has had a weak launch, with very few games worth buying. Even resistance is average at best. It does nothing new.
It will be great in the future but definetly not now.
PlayStation 3
CPU speed: 22.4 GHz
Overall CPU performance: 204 gigaflops
Xbox 360
CPU speed: 9.6 GHz
Overall CPU performance: 115.2 gigaflops
Give it a year & they’ll be creating much more amazing results with the new cell processor in the PS3, it's only early days.
And where did you get those figures from??? just curious, i must be looking at wrong sites.
yeah those figures are total shit
wtf did you get them from ?
Xbox 360
Custom IBM PowerPC-based CPU
• Three symmetrical cores running at 3.2 GHz each
• Two hardware threads per core; six hardware threads total
• VMX-128 vector unit per core; three total
• 128 VMX-128 registers per hardware thread
• 1 MB L2 cache
CPU Game Math Performance
• 9 billion dot product operations per second
Custom ATI Graphics Processor
• 500MHz processor
• 10 MB of embedded DRAM
• 48-way parallel floating-point dynamically scheduled shader pipelines
• Unified shader architecture
Polygon Performance
• 500 million triangles per second
Pixel Fill Rate
• 16 gigasamples per second fill rate using 4x MSAA
Shader Performance
• 48 billion shader operations per second
Memory
• 512 MB of GDDR3 RAM
• 700 MHz of DDR
• Unified memory architecture
Memory Bandwidth • 22.4 GB/s memory interface bus bandwidth
• 256 GB/s memory bandwidth to EDRAM
• 21.6 GB/s front-side bus
Overall System Floating-Point Performance
• 1 teraflop
PS3
CPU: Cell Processor PowerPC-base Core @3.2GHz
--1 VMX vector unit per core
--512KB L2 cache
--7 x SPE @3.2GHz
--7 x 128b 128 SIMD GPRs
--7 x 256KB SRAM for SPE
--*1 of 8 SPEs reserved for redundancy
--Total floating point performance: 218 gigaflops
GPU RSX @ 550MHz
--1.8 TFLOPS floating point Performance
--Full HD (up to 1080p) x 2 channels
--Multi-way programmable parallel Floating point shader pipelines
--Sound Dolby 5.1ch, DTS, LPCM, etc. (Cell-based processing)
MEMORY
256MB XDR Main RAM @3.2GHz
256MB GDDR3 VRAM @700MHz
System Bandwidth Main RAM-- 25.6GB/s
VRAM--22.4GB/s
RSX-- 20GB/s (write) + 15GB/s (read)
SB2.5GB/s (write) + 2.5GB/s (read)
SYSTEM FLOATING POINT PERFORMANCE:
2 teraflops
on paper the ps3 has more processor power
but 2 things stand out immedietly:
Multithreading 7 processors effectivily is difficult and makes larger code that is less eficient.anyone remember the sega saturn ? it was effectivily 2x as powerfull as the ps1 , could even do basic 3d shading similar to n64/voodoo 1 1st generation 3d machines . but it was very hard to program efficiently and many publishers just gave up virtually no one used it to its full capabilities and most cross platform games were identical between saturn and ps1.
and
PS3 and 360 have similar memory bandwiths . they will both have a bit of a bottleneck there as time goes on . this will tie the ps3 down a bit more as its raw processing speed is higher but it will struggle to use it all against its memory constraints . going back in time early pentium 4 processors which didnt use ddr memory buses were actually slower than pentium 3s until we got ddr , ddr2 and rambus to lift that bottleneck . even now memory bandwith is paramount and always and issue with all modern processors including these consoles . this will definetly tie the 2 machines together a bit more than processor power suggests. also i like the xbox360 unified memory achitecture . games these days are generally graphics heavy and its a good idea to be flexible in opening up as much resources to graphics as you can . wont be a huge biggie but a good idea.
this is not ps3 bashing , ill be getting one . just dont expect games that are a full generation ahead of the 360 . they will probably end up being better but only slightly . there will be no major quantum leap or anything like that. think ps2 vs xbox . xbox is generally a bit better but lots of games are virtually the same on both platforms. a lot of that is publishers economy of scale too , no point making essentially 2 games when you can make 1
Edited by arkon
Wikipedia & other sites, simple google search. It's the total CPU processing speed.
Oww & don’t give any weak excuses about the new cell CPU being too hard to program for, sure it maybe be difficult in the beginning but anything is when you have to learn something new, with time they’ll master it. Then for the next generation there’ll be something different again, & then they’ll have to adapt & utilise that technology, it’s just the evolution of computers really.
I’ll agree the launch could have been better but I wouldn’t call it weak, GT HD is fair f'ing impressive! looking forward to games 1 year down the road.
I found this pretty interesting on the Cell processor.
http://en.wikipedia.org/wiki/Cell_microprocessor
Edited by geno8r
So this is turning into system wars.. Hardware definately doesn't give a console the upper hand.. Lets look at XBOX vs PS2, PS2 sold a whole lot more, and its hardware was pretty inferior compared to the XBOX.
At the moment, there's nothing out, nor will there be in a year or two that will completely use the 360's processors. Games that run on a 2Ghz pc, ran beautifully on a 700Mhz XBOX, and however odd Mhz the PS2 had (300-400). Consoles don't use full operating systems and therefore aren't tied down as much as computers.
Currently the PS3 doesn't have any strong titles on it. And by that I mean titles that define the console. The 360 has a few. And currently it has the upper hand.
To think hardware is what defines a console is foolish. Look at the wii, It's got the hardware of a gameboy and still its innovation and makes it great.
Ps. what's up with the 360 elite... what a waste of money >_>
Yes mate I have had first hand experience, and as for online game play I'd hate to see how long you would have to wait to get a game with it taking so long to load.
umm?
have you played the R:FOM online? loading time is not long at all...
What do you want from launch title games?
ohh and fanboys are funny LOL!
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
