How much? Would I fit in one? Is it easy to die in one?
well, like most things you can spend small or big. Yes, you could fit in one. Most of the good guys in superkart are over 30s, and some have a bit of extra meat on them, and seem to cope ok. Unlike the smaller kart classes a bit of extra weight doesn't give you the huge disadvantage as you have gears and power to help with that! plus it seems to be that the prime factor is the size of your nuts.
Tyres are cheap and last a few meets, fuel is negligable engine rebuild is not huge either. Plus the only thing quicker around EC is an F3 car...
i'm sure it is quite easy to die in one. karts have no brake lights (the only form of land based motorsport that doesnt I think) and i'm not sure if they run seat belts or not. But Karts are easy to repair if you bend them.
Adam, next round of the state champs come out with me and we'll check them out. It's amazing how quick they are for so little money. And mostly if you buy second hand it will come with a small trailer, stand etc.
  • Replies 79
http://www.my105.com.au/classified.asp?id=5792
in ur budget but race only :S
This looks pretty sweet. good power for the money: http://www.my105.com.au/classified.asp?id=6136
A bit over budget tho :P
Edited by JaFF
if we are getting up my105 adds then this could be a go-er:
http://www.my105.com.au/classified.asp?id=6096
possibly even be able to register it again if you wanted to. 4AG 20 valve with close ratio box beats the shit out of most $10K cars...
The only time I went to wakefield, they had a group of gen 1 swift gti’s for one of those track days where they give you a car and an instructor in a track car.
They were stripped and caged.
And they were screaming.
Failing that..
86-88 corolla 1.6L twin cam.
Any gen Starlet turbo you can buy for the price.
I think the Gen1 (88 model) starlet is about 750kg..
Look like this..
Gen 2 – 850kg?
90-95 model)
Gen 3? – 900kg?
96 - ?? model
They have 100kw stock.
Whiteline have a suspension kit for it that I believe SK from here helped put together..
$5K on the motor will have it running 12’s so imagine it on a track.(that money gets you turbo, cooler, pump, injectors, ecu and tune.)
Strip the interior and it’s even lighter.
Brakes can be upgraded from a celica gt4. but at the weight it is, you won’t need to.
I just did the most implusive thing... I bought that ex-race/rally TX3 Laser that Adam linked too earlier on !. Got it for next to nothing as it needs a fair bit of work and is out of rego.
It's a 1988 Tx3 turbo - 4WD. What model is this KC / KE ???
It's got the original 1600cc turbo motor - has been rebuilt 40,000 kms ago. It also has a re-built gearbox not so long ago - got receipts for this. So the Engine and gearbox seem good. After driving (on private property of course, the engine seems strong and gearbox doesn't crunch or anything)
Car came with race (rock hard) coil over suspension. By the sounds of the rear - there is a fair bit of rattling around - so I think all the suspension bushes etc need replacing.
Being ex rally, I think the centre diff has been locked - as the tailshaft is out and runs in FWD mode. Car came with the tailshaft - so might have to get a new centre diff to get the 4WD working again.
Engine is controlled by a Haltech ECU - it hasn't been tuned for cold start so it takes a while before it idles nicely.
Wheels are Simmons - 15" I think - they seem in good nick.
Seats are racing type and will need to be replaced for rego (if i ever get it to that stage)
I got this car as a project for myself - I'll put it back to road worthy bit at time.
I'll be in the market for some bits and pieces so I'll keep my eye on the classifieds here.
I'll post some pics later.
Cheers,
B-Man
I'd go with Roy with the Mk1 Escort, I had a coupe set up for rally years ago and theyre a damn fun little car, bit hard too find these days because people like me kept munting them into rocks and trees :(
Guess a bit more looking around and you might be able too lay your hands on a SSS 180B for about 1-2k at the most for a decent-ish one. Leaves a lot of money for spares and fiddling. Plus its a 180B, no one ever suspects the 180B :P heh!
Owned both, had me a lot of cheap fun and thrills in them.
Edited by MK2
most datsuns would be good. you can buy complete bolt up kits (engine mounts, gearbox mounts, etc) to fit a sr20det into them for about $1000. 1600's are popular for putting sr20's into. if you want rwd, you can fit an sr20 into geminis, sigmas (mate has a 12.56 second sigma with a stock sr20 in it, just has a problem with diffs breaking), escorts, datsuns.
a gemini with a v6 commodore motor in it would be good fun too.
or a datsun 1600 with a worked L20 would be good fun. they rev to 9000rpm without any problems. my mate with the sigma also has a worked L20 2.2L stroker sitting under his house that is good for about 190hp. he's a mechanic by trade, and built it up for his borthers 1600, whcih they then put the sr20 thats in his sigma into.
what a small world hey Brendan.
I buy a car from you, then you go buy a car which I owned about 6 years ago.. LOL..
I had that car registered with those seats and harnesses.
Yes the suspension is damn hard.
But if you get that 4wd working again, it does turn pretty well..
Front brakes are from a VL turbo just in case you need to replace bits.
It has no cat.
And when I had it, it was running on SUPER .
The haltech has been repaired before. It had a crack in the board.
I hope it’s been tuned since then cause it had a few problems after about 20 minutes of driving.
The injectors when I had them were some bosch items which were same as some 944 turbo Porsche.
It had no bov
The turbo is a stock ihi rbh5 hi-flowed.
Clutch was a 5 puck ceramic button clutch.
I can ask my mate if he still has the roll cage for it if you like.
But it was a proper rally purpose cage.
Oh Sweet - ! How funny !
I figuerd he cat thing ! :rolleyes:
I can't work out what model Haltech it is ! And how to tune it ? Does it need software ? It does need a bit of a tune - Cold start is crap.
What's the ECU adjustment knob thing ? Ray told me air/ fuel - but I find that hard to understand.
It needs a bluey - so not sure if seats will pass.
Hand brake is hydrolic - so might need some work for bluey.
Also might need to hide the brake bias adjuster.
Something is draining the battery when switched off - thought is was the fuel pump (seems to be on all the time - so that needs rewiring to ignition)
Man - it has some awsome potential - but whoever worked on it recently has done some dodgy stuff :wave: ha ha ha
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
