My Slyline, Jay Stylez have u driven through bowral a couple of times before? swear its yours ive seen going back a fair few months now but
Was this car at JEM last week?
It was on the dyno i think. Was the engine built by Autosport? Heard you have had some bad luck with engines?
ah its no drama..one night of snow and light and flufffy...Was too smashed xmas too put it in the garage and we had 50cm overnight..Fairly common here..Only damage was my body..shocking hangover and hour to shovel the car out..
Edited by elrodeo666
A snow flake is light and fluffy, that on the other hand is not so light and fluffy.
ie: 1 tonne of feathers is still as heavy as 1 tonne of iron.
But i was mainly referring to the environmental conditions the car is in and all the inherent issues that it will cause over time.
Where do you think every other Skyline in Australia came from?
The enviroment here is super dry in winter, much much drier than say most places in oz, thats why so many aussies come here for the snow, its the driest on the planet. Car is normaly garaged ! Seeing I've been here for nearly 10 years my concern to you would be the fact A) I know the history of my car
(B) most cars here sit in car lots for god knows how long without being started before they ever make it to auctions and they cop the full brunt of weather and acid rain,
© most japanese drivers wouldnt have a clue where the dip stick is..they drive their cars, put petrol in , and most dont dervice their cars until they have to do rego (shakken) which is every 2 years..
Trust me, a bit of snow is nothing compared to what I've seen some GTR's go thru before being shipped off to auction..
I'd take 50cms of Hokkaido light fluffy super dry snow sitting on my car for 1 day anytime compared to harsh aussie climate.
What's your point???? :D
Not all imports come from the snow covered mountains. The cheaper ones are covered with rust due to the salt roads in these areas. Just raising the question whether someone would buy a cheaper import if they saw the car covered in snow, like that one was.
^^ thats mint.
rekn you should swap the wheels off your GTST tho, and lower it a tad :D
Cheers ;)
I actually sold the work wheels of the gts25t a couple of weeks ago, they wouldnt have looked very good on the gtr because of their sizes and offsets anyway, not to mention they had different sized tyres front and back so would mess with the ATTESA.
I agree with the lowering part, it does sit a little bit high, but overall i am actually very impressed with the stock suspension so might just go with some Tein springs and also some wheel spacers, should make it look a bit nicer!
Edited by nizmo_freek
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
    • The detail level is about right for the money they charge for the full kit... AU$21.00 each issue, 110 issues for a total of $2,300 (I mentioned $2.2K in the first post when the exchange rate was better). $20/week is doable... 😐
    • If planning on joining us for the day(s) please indicate by filling in this form. https://forms.gle/Ma8Nn4DzYVA8uDHg7
    • You put the driver's seat on the wrong side! Incredible detail on all of this. It looks like you could learn a lot about the car just from assembling the kit.
