  On 11/06/2013 at 9:23 AM, boiracer said:
this combo looks awesome. Not normally a a fan of series 1-1.5, but this is real nice
Second that. I replaced the whole front end on my car to S2 because I didnt like the S1 front. but that actually looks really good
  On 11/06/2013 at 8:25 AM, Miguelone said:
Needs Hasemi lip for type M frontbar now :P
Im surprised someone else knew about that! Cant wait to get one for my R33. Ive only ever seen one R33 with one besides the demo on the Hasemi site. It was that white rb25/30 one that was for sale ages ago.
  On 11/06/2013 at 9:51 AM, Miguelone said:
Yeah I never liked it much either till I saw that, just classys up the entire front. Also shame they cost so much but hey, gotta pay to play. Tis usual of high quality Jap stuff anyhow.
Last time I checked they werent that expensive?
Just had a look now, 37800yen.
According to converter, 37800 yen = $390...... DAMN, could have sworn that used to equate to $200 -_-
Either way, I am still going to get one eventually. I have LOVED the type M series 1 r33's since I ever got into cars all togethor, was stoked when I found that lip existed as it looks soo good haha.
there was a red one that used to get work done at RE with the hasemi lip for the type s bar. going back a few years now though
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
