Not saying it's a good idea (personally I reckon it'd be a bitch on fuel, plus no fun to drive) but from memory there's a QLD GTST, and one from Vic running powerglide transmissions. Both are daily driven. Not sure if there's any info on SAU, but could be worth a look.
There is a marron gtst with plates H8 GRIP or something like that in qld that has a powerglide in it.
YouTube r33 powerglide it's the marron one
What trans temp does it run at...?
I am using a 30row engine oil cooler for mine. Trans temp hasnt gone above 60degrees while having some spirited driving.
f**k knows, its just the car to take kids to school ..i put them both in there as i had them sitting around and a "built" RE401RB box is marginal i think once i fit turbo and run 22psi with the weight of the car. I just wanted to take no chances,as heat is the biggest killer of auto boxes . i found one cooler with transbrake and slippery converter wasn't that great in R31, will be having 2 in R31 next time aswell, its quite normal in the U.S, here i only commonly see one fitted.
cheers
darren
My cooler setup, two 30 row coolers, one 12an for oil and one with 8an for the trans. (plus the PS cooler.) Not much room left. lol.
The engine oil cooler has a 14 inch fan on it, and the transmission one has a 9 inch spal. Both fans electronically controlled off temp sensors in the cooler return lines.
Mine is a bit more of a squeeze than that. I dont have room for fans and my coolers almost touch side by side. Even with the grout in the block water temp still seems fine :thumbsup:
Edited by WHITER33GTS-T
hey guys , as stated above heat is the killer of auto boxes
recommended transmission coolers for my r33 gtst series 2 for easy fitment and good quality?
how much should I expect to pay to install it? (cant and wont do it myself as im mechanically retarded)
get the biggest one you can from Supercheap or whatever - shouldn't be more than an hour's labour to install - get some quotes if you're worried.
Read this even if you don't plan to do it yourself:
http://www.skylinesaustralia.com/forums/topic/59399-transmission-cooler/
  • 3 weeks later...
Replace the coilovers with stock suspension, put smaller rear wheels 15/16 inch with street drag radials, hi stall torque converter, mv auto shift kit have some fun.
My question, how much can a stock 32 auto take? Has 33 turbo with vg30 rear housing and supporting mods.
Thanks for the advice. Its my daily and I want a nice looking car with a bit of poke , so I dont really want to ditch the coilovers and run 16's.
Would a high stall &/or a shift kit net me a second? really want to get into the 5's
what are you guys doing 0-100km/h in your auto's?
A shift kit is a must at much over stock power.
All a high stall converter will do for you is to lose you power, but it may help get you off the line a little quicker. If you have the stock turbo, leave the converter alone.
thanks for the input. Why exactly am i so slow getting to 0-30km/h and the engine only really starts pulling hard to 100? Cant be that much turbo lag since its only a tiny turbo on the rb25
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW )
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
