  • 1 month later...
Man what happened to all the auto guys? This thread is dead...
Are these the options or tuning the auto skyline r33 :
Toshi's tune
Nistune..need more info about this
eManage blue/ultimate
Safc and sitc
Power Fc
Are these users able to retain the shift logic? Toshi is all out of auto ecu's and wont be importing anymore so I dont know if he is an option. He mentioned not being able to do over 200rwkw or so on the eManage.
Want to see in excess of 230rwkw (have usual mods - intake/exhaust , injectors , fuel pump - high flow turbo to 18psi , trans cooler , mv valve body upgrade)
What ecu can I use that will retain daily drivability but get me to 230rwkw?
A few Options
Adaptronic E1280, Wolf 3D V550, The Newer AEMs can do it, Holley Dominator EFI will do it shortly
Toshi's tune
Safc and sitc
Power Fc
A few Options
Is this true. We used to be looking for ecu's to retain auto shift logic everywhere. Have I been that behind the times or do all the above retain the auto boxes shift logic in an r33?
Stu released a Type 6 board (still beta/prototype) to nistune your stock ECU (in the past had to be a Z32 8-bit ECU)
There was a thread started in this forum, however r31nismod decided to delete it because it sounded too much of a trader ad.
You should speak to Mat from Nistune, he might have a solution for you retaining your factory ECU, however with the new type 6 nistune board.
I, myself have not used (type 6 that is) however it looks very promising, have however used/tuned other nistune vehicles and it's great.
They're piggy backs. dvs jez has tuned an adaptronic on an auto 33. If i recall the mods correctly it would have had around 280kw
Thanks will have a look and report back
best part about nistune is their trace functionality, shows you a load trace and display afr or whatever value you want
other ECU software you need to log, then read the log for that view (just makes it a tiny bit more time consuming)
I've been following Stu's post, seems the 1st batch were slightly dodgy however it appears it may have been fixed.
Why? If he is worried about knock, shoving e85 in the tank will fix that...
I have seen 250kw easily on petrol safely, and over 300kw on my Ethanol Emanage Ultimate tunes. I can't see why the VQ would be any different to RB tuning...
I think he's missing a vital piece of information, and that's probably the stock automatic gearbox will go kaput with over 200kW
Only just found this thread so sorry if i have missed this but y cant we just put a manual valve body in and wire the od switch into a diffrent power sauce and just run a manual ecu ? O and I have a r32 with 220 rwhp probly a bit more now and a 3500rpm converter and loving it.
I believe you can do exactly that.
It is also possible to have a completely standalone computer (at least for the R34) for the automatic side of things. This is probably 'better' than going full manual, because you can configure absolutely everything that a transmission can do.
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
