Yeah, both front and rear uni's look to be beefier than the ones on the 33 tail shaft. Rear one is rebuildable, front one isn't.
If you think 575 was pricey, I was quoted up to $1200 from other places.
I have a 33 speedo drive which i have adapted to the back of a 32 speedo face, in the process of jury rigging it atm to see if i can get it working before hacking up the back of the dash. If i cant get it, then the navara drive goes in. Only concern then is physically fitting the cable up to the drive as there isn't much space in there.
  • Replies 188
Posted Images
$1200!!! Made of carbon and balanced to 400kmh??? Far out some people think they can have a lend.
I guess mine did have problems at first, and in the end they had to pay to put the better unis on not me, which I would have had no problems paying in the first place, but as they say thats the way the cock flops.
Well after a week of mucking around with the r33 cluster and then an s13 one just in case the 33 one was cactus i grabbed a 32gtr drive (thanks risking) and used that.
The shaft is about 10mm shorter than the VL/navara unit so that you get away without removing the key way. and the bottom section of the gear is a nice interference fit over the splines requiring the bench vice to press the gear on. I just chucked a bit of loctite on the splines before installing.
I found that i also had to cut a new slot but only about 120 degrees around, rather than 180 as booster suggested.
Also bashed the bottom edge of the tunnel a bit to give a straighter shot at the drive for the cable.
Has anyone had cable failures due to the tight bends? or has anyone gotten a replacement shorter cable to suit the different drive position?
Edited by BHDave
How much would a mechanic charge to fit a r33 gearbox into a r32?
Thanks
Well, my total conversion cost about $3400... But that included the box and a jim berry clutch, and the one peice tailshaft, not that that cost much more than getting the standard one modded.
So say minus $1400 for the box $1200 for the clutch, mine cost $800 or so, inc the tailshaft, and a few misc bits. But thats also removing the existing box, and he had never done the conversion on a cefiro, so there was a little experimentation time.
  • 2 months later...
i went to nissan today they dont make the r33 speedo cog anymore, or the whole drive!!! and they dont make the navara pinion assembly with the 21 tooth cog..
does any1 have a spare r33 pinion assembly? or are any others the same? i only want the cog off it!!
my tailshaft only costed me $100 i used my r32 tailshaft and just put the yoke off the r33 tailshaft on it..
Tried it, couldn't find the info on how it's wired, wasn't lucky enough to guess it.
r33 speedo has 4 contacts on the back, one positive, one neg, and what i think is a signal in and a signal out. The speed sensor is a hall effect from memory which means both wires will give a signal, provided the other one is earthed. So through educated guess you can figure what has to go to the dash. Without tracing wires through an r33 you don't know what has to happen in between, which was the point i decided it was all too hard.
The dash requires butchering to fit the 33 speedo mechanism. it's a harder job than chopping off a cog and sticking a the 25 one on there
  • 1 month later...
So to round up the three pages what steps or items are needed to do this conversion?
Longer size bell hosing bolts, what sizes?
Tail shaft with R33 yoke, whats best or cheapest, custom one peice or mod the stock R32 one?
Cluch slave. Does anything need to be done to the bearing, housing or clutch fork?
Without going into debate, is there one setup for the speedo drive that has worked without trouble?
A custom cross member, anyone have a pic of theirs?
Slight change of trans tunnel shape, pics?
thanks
Daniel
(starting to sound like its gonna take me more than a morning to do this)
Edited by =premo=
I found a place in NZ who does a replacement part to convert the r33 box speedo to suit r32
I spoke to him today and mentioned Navara parts and he said he didnt use them yet mentioned it was genuine nissan and they had never had problems.
75 NZD and www.dodsonmotorsport.com
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
