Ive got a link G4 sitting in a box waiting to go in :)
Was just looking for the stock ECU brackets because I think mine have disappeared off the ECU. Think I tried to fit them to the power fc but didnt work so they got seperated. Not to sure. Was going to pick some up from a guy but I was busy then txt him a few days later and havent heard back
Ive been doing some wiring the last 2 days. The results of wiring gauges etc in at different stages meant there was alot of messy shit everywhere. I used a crimp joiner to put my wideband gauge in without even bothering to fuse it so now ive fixed all that. Just need to find a constant power for my oil pressure gauge and connect it up then it will pretty much be right
We've made up some pipes for the coolant so we can tee off to the turbo and wastegate then tee it back together in the return. Not sure how necessary it is to water cool the tial gate but at leasti should never have to worry about it
Had thought about painting the intercooler pipes silver. Think it would look heaps better. But im getting to close to engine in that I dont think I can be bothered.
are you chsing the bracket for the ecu cal. ive got a spare at home
yeah ill send a pic to you.
Thanks for the pic yesterday man
Turns out that when I put the Power FC in, I tried to use the stock brackets on the Power FC, but when that didnt work I bolted them into the car and have been sitting the Power FC in the brackets since then.
Bit of a silly one that one lol........
Pretty much done all the wiring bar the MAP sensor and wiring the wideband into the link now. So just about ready to chuck the dash back in. Dad's going to clean up the rest of the bay for me while I'm at work so next week when I get back it should be engine in time.... Finally :)
I should really start a build thread......
Sorted the brackets out for the ECU, turns out my Power FC was in the opposite way to the standard one, but it worked
Got most of the dash back together, just gotta finish wiring up the launch control switch
Spliced the Analog out wire from my wideband into the ECU today, Hate cutting wires at the ECU plug lol.... Hopefully it works a treat
Get off night shift and decide to build brackets. Only problem is I started out wanting to build an oiler cooler bracket.
Doubt this will ever break. My MAP sensors used to be held to the throttle cable bracket with zip ties, so this is a bit nicer :P
This thread is my build thread now to BTW.......
Bens to busy playing with Toyotas lately :P
Nah ill do a build thread when its done probably. Still trying to sell my turbo kit to. If anyone here wants it or has a mate that wants it then ill do a deal. I have $1200 on it atm
Dont want to have to post it if I can help it
I want to bring it down to Bris, but will be a while before that will happen. Have to do alot of testing and let the thing run for a bit
Be a shame if it blew up, let alone half-way to Brisbane lol
Oil Pressure gauge installed. Have run out of room on the A-Pillar, and seen as I wont be looking at it as much It's mounted low. Dash has also been freshly painted. Its a bit of a lighter silver, more of a metallic grey, Bit nicer then full silver although it looks pretty silver in the photo:
And a shot of the engine with the Pressure test gear on. Pressure tested the coolant side of things, Dad found a leak in the rear block welsch plug, so that would have been a real pain (gearbox out) job to fix. All good now anyway. Let the thing sit with 1bar pressure in it for about 2 hours and next to no pressure drop and no leaks visable.
Off to do more engine bay prep today. Might have to check the intake side of things with a pressure tester if I can make one up to fit
Edited by 89CAL
Finally got around to making an oil cooler bracket, Turned out alright using a stock bracket off the car (still not sure what it was actually doing on there though)
And started prepping the engine bay. Spend some more time on the bay today and hopefully engine can go in sometime before I go back to work next week
Engine bay done. Could have spent more time and done the lot but don't have the time anymore. Need to get the thing done. Clutch off to get a rebuild. Its still in great condition. No hot spots or signs of damage. Just worn the material down. NPC (Y)
Posted Image
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
