Here's what I do.
I tune the car at the fuel I will use everyday.
Which is Mobil Synergy 8000 (Yay for Fuel Cards!!)
Then, put a gut full of V-Power EXTREEEEEM RACING SICK BRO VTECH YO fuel in and take the car to your tuner.
Have then spin the thing up on the dyno and using the blanket adjustments in the PFC adjust fuel and timing to suit.
Then, when you want to go racing, put the fuel in, adjuste blanket timing and fuel numbers and go play.
that way you don't have to get nervous about going long distances and not have access to the fuel.
Also stops you from having it tuned with the good fuel and having to adust blanket numbers every time you get in your car.
:D
BASS OUT
  • Replies 54
I use it in my car and it runs really well, Ben from Race Pace insists it is the only fuel i should run my car on after he tuned it.
Because if a car is tuned on 100+RON fuel, and then driven with 98RON, its like a car that needs 98 being driven on regular....knock time
Really? I have ran mine on 95 and it was fine. I didnt run out running big bolost or reving the hell out ot it. But it drove fine. No pinging at all. Though i wasnt game to give it a good few hits and try and get it to knock
lol well there you go. Drive the car how it was tuned to be driven, ie giving it some boost and I think its safe to say it'd ping.
We could probably all fill up with 91 RON and be fine, but as soon as soon as you hit boost i'd say it'd be all over.
But you dont need to drive around doing fully sick 7000rpm gear changers during everyday driving
Yeh thats my point. I gave it a few runs using 8psi (my lowest boost setting) and the thing drove fine. Not every drive down to the video shop is a GP :)
Though after doing it for a few weeks i thought to myself "stop beign such a tight ass, its only a few dollars extra a tank" but i did with no real probs.
Main reason i stopped doing it is i kinda guess if i was going to get a dodgy tank of fuel with water and crap in it, perhaps it was more likely to come with the crappy fuel?!?!?
Did I say I drive like that everyday?
personally I have only ever used 98RON, and I see no reason to use anything else. I knew the car needed premium when I bought it, so thats what it gets, and I do a lot of km's.
all this V-Power is just a marketing exercise. Its just the same Optimax and Optimax extreme but rebranded to go with the global Shell marketing name.
as long as everyone knows that optimax extreme has 5% ethanol.....and ethanol leans out mixtures by quite a bit.....
are u sure the v power is the new "optimax extreme" ?
i always thought the v power stuff was red at the bowser and is the replacement for normal optimax and that optimax extreme was still called that and avaiable
Well i just found out that it looks as though i am running ths straight V-power, not V-Power Racing.
I can say that there is no way V-Power is the same as Optimax, as there is no way my car use to run as well as it currently does on Optimax. Let alone the extra ignition the engine it is taking. My car normally ran better on the BP and Mobil fuel.
The fact that the straight V-Power is performing the way it is...im very interested in running the V-Power Racing.
Optimax and V-Max are different blends, with Shell now having removed the toluene that was used as an octane booster in Optimax. Both the V-Max fuels are blended to European emissions standards as well.
the PFC FAQ tells you how to use poor mans 91 and 93 ron fuels
ive done it a few times in shitty towns that have only pesant fuel. as long as you don't load the engine up and come on boost over and over it should be fine.
just watch the knock levels and keep backing more and more timing. it will flat as a $2 whore but will drive fine and get you out of a sticky situation
:sorcerer:
i got the beast tuned to 265 racepace rwkws on ultimate..
Ben suggested i use v-racing and i am very impressed with it so far...
car feels stronger and more responsive with v-racing as opposed to ultimate...
On my third tank...
i usualy get around 300kms on BP ultimate. I am getting 320kms on VPR... But my custom tune which was originally for BP 98 is working much better on VPR. Heaps more mid-range from my seat-o-pants meter.
Only thing I have noticed is at high RPM in 4th gear the car is tapering boost out earlier...
Yeah, its cause its leaning it out ever so slightly and your getting a little more power from it :P
Finer6
What mods are you running in your typhoon to get such low milage?
Nispro XR6t power tune... not the economy one (obviously) hehehe :rofl:
It smells like optimax and tastes like regular petrol.
I found shit-f**k-all difference between it and the old optimax in my r32... dad's aristoid got 20km's more, but I'm guessing that's coz he didn't give the 2JZ enough curry.
I prefer the BP Ultimate.
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
