after a series 1 r33 dash cluster reading around the 130 thousand mark (old ones stopped ticking over and need a replacement
any help is appreciated text me on 0422360999 for a quicker response
Aaron.
I have one but its 149k kilometers... and for an automatic....
Im about to put it on ebay or throw it in the bin.
Item
R34 steering wheel, with airbag.
Good condition and Ill pay what its worth.
contact details
pm me.
Auto or 5 spd
S1 or s2 ?
How soon ?
might have my s2 5 spd up for sale soon
silver and black
gotta fit my carbon and leather nissan airbag momo
After a boost gauge. Condition etc doesn't matter, I only need it to check the accuracy of my EBC so won't be mounting it in the car. Looking for something relatively quickly. If you have something send me a PM!
I'm looking for some cheap 17" rims to fit a V35 Coupe - standard V35 rims (17x7.5 front, 17x8 rear, +30 offset) would be perfect, or something similar. I'm not too fussed about gutter rash or scratches, just want them to fit old tyres for motorkhana type events. Anyone got suitable rims in the shed?
Edit - with or without tyres, tread or no tread
Edited by GeeDod
