  • Replies 145
zomg thats almost as bad as the s2000 2jz conversion.. least that was an improvement
this on the other hand is death. altho would make it easier for big turbo conversion having the inlet on the same side as the brake booster n shit on the lhs when converted....
but still this is a sin that will send anyone straight to hell. arabs n all shit, i dont care
all it needed was a hks rb28 kit n would kill any 2jz
RB26>2JZ
not 2 mention a shit load of oil/petrol
U.A.E Will be the first country to run out of oil, Hence why they have tried to turn it into a business and trade hub.
Petrol here isn't as cheap as most people would think.
In Saudi on the other hard, I pay 15cents a litre! Now that is hell cheap!
Cheers
Josh
i wouldnt mind it so much if they worked a miracle and kept the awd, then atleast i could live with it, respect the 2jz
admitedly pointless if your going for this sort of setup maye aswell of replaced a 25t, that would be meaningful atleast !@
love the Top Secret TE37s, but those fenders are horrible. even if the style is not to my taste (which it's not) at least they quality could have been good, but it's terrible. The engine work also looks like arse, but the idea does have some merit and if it runs well will be quite fast. considering the car was possibly stolen in japan and sold to someone in UAE for $10 or $20K then it's not a bad way to build a cheap fun car.
still such a butchered car by now considering the LHD conversion, the dodgy kit and the engine swap. :ninja:
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
